105
you may have 2 problems, you may have 5 - but here's some things to check; many people find cracked knock sensors that didn't cause a CEL. Oil in the plug holse/on wire boots will cause missing - as will bad spark plug wires (OEM wires preferred). Some folks confirm bad wires/coil at night , engine idling, by using a plant mister to spray watter on the high voltage parts - listen for engine stumbling and look for arcing. you should still rotate front pair of tires with the rear to monitor for a change in the wobble. Check inner tie rods for play, they might clunk. Inspect the rear bushings for the lower control arms. they can clunk. Both those can make a wobble. Noise up front could be several things but; check for air in the power steering reservoir - there should be no bubbles or foam. Ait intake filter box might not be securely clipped-in at the bottom. Wheel bearing could be bad. Not a bad idea to confirm brake calipers are sliding well.
details on car? year/miles/condition etc.
clacking? you said speed of the car - so, the clacking is also car/tire rotation related? not engine rpm? I'd say clacking could very well be a CV joint. auto or 5spd trans? sound left, right or center? (have someone else drive and sit in the pass. seat) when was the last timing belt systems service? who did the work? take a close look at the crank pulley while idling. running true and straight? no wobbling?
^^^^ wisdom right there. coupla small things that I've done based on reading and experience. put 2 small zip-ties or a small clamp on the overflow tube at the nipple on the radiator's neck. it may be possible for air to be drawn in as the rubber ages and gets less compliant. Pull the other end of that tube up outta the o'flow tank and cut he end at a 45* angle to help prevent the bottom possibly being blocked. A new radiator cap may be a good idea as well.
easiest mistake that might create more noise would be not getting the airbox seated properly. can you describe the noise more? is it a whoosh or a ticking or ??? these cars also can have loose heatsheilds. what shop did the work? if they are unfamiliar with Subarus, maybe a mistake was made with draining/filling the correct fluid - check fluid levels ASAP. consider taking it back and take someone for a ride to demonstrate the sound.
first, I HOPE he checked his engine oil level. perhaps checking voltage at the battery while idling would be good - to confirm he doesn't have low system voltage. Having a mechanic confirm he actually has low oil pressure - vs an intermittent sensor or other electrical problem - would be the best place to start. Those oil pressure swiutches/senders come on at about 3psi I think ! If you want to risk losing a little time and money, the pressure sender is located sorta under the alternator I think. Not hard to change. You can probably do a search for pics - might even find a youtube video. if he actually has low oil pressure - it could be from extreme wear on the bearings, it could be loose screws on the oil pump's backplate, dented oil pan/cracked oil pick-up tube, a few different things. edit - beat by my slow typing!
look around the steering shaft u-joint. i have read of it abrading through a wire harness.
- 3 replies
- impreza
- making turns
(and 2 more)
Tagged with:
