105
I'm a flatlander too but sometimes visit my oldest daughter in CoSpgs. (others here may have better advice) def. downshift on down-grades to prevent cooking the brakes. drive a little slower - but, the car is not going to 'blow-up', it's downshifting actually reduces 'lugging' the engine and reduces it's load. Forcing a car to remain in a high gear under load can lead to overheating and poor lubrication. keep the car in good condition - fluid changes, bled/flushed brake system, good tires, etc. RetroRoo is too far away, but Shawn (owner of this site) may be able to recommend a shop to your son that is in/near G'd Spgs. http://retroroo.com/
if you could find STI engine and drivetrain, would be awesome for a track car - but probably MUCH easier to find WRX. get the rear diffs - final drives must match front and back. plenty info at NASIOC too for stuff like this. Those guys are kinda snarky so, do plenty of reading before asking questions and put on something flame retardant.
run the suggested octane - probably premium (that's what I run in our 03 H6) it can be tricky to 'burp' all the air out of the cooling system in Subarus, (helps to either fill the block thru the top hoses, or get the nose up in the air. Also, put a tiny clamp or a coupla small zip ties on the little overflow hose at the nipple on the radiator's 'neck) plus , they need a thermostat with a larger wax capsule - so, over time and multiple owners, the cooling systems get abused and an engine is overheated. Very rare to hear of someone rebuilding an H6, even the H4s rarely get their cases split it seems. Get an engine from a wreck - maybe JDM as said - that's a common swap when folks have overheated soob motors.
there's a dedicated Forester Forum, those guys could probably tell you how much your car varies from the average. you might check the inner tie rods and get an alignment. any vibration at the tire or misalignment could affect mileage a little. I'm 61 - can't wait to get my WRX back so I can zoom around. I like cruising in the wife's Outback, but it's a pig in the corners lol!
"it's more fun to drive a slow car fast, than a fast car slow" you might try to get him involved in SCCA and local autoX. There are 'classes' to compete with almost any kind of vehicle. I also recommend HPDEs . wish I had paid for my kids to go a coupla times. (cops won't let you go straight very fast, but they don't care much how quickly you turn) that said; best power upgrade is sell what you have and get a WRX that hasn't been reamed-out by someone else's 18 yo son. next best is probably a wrx swap. You may want to read-up a little over at NASIOC.com . If he just want to drive a car fast in a straight line, just get a Mustang. if he wants to experience acceleration, get a motorcycle.
I could really use a 3rd car - AWD Tuning has been rebuilding my WRX's transmission for 3.5 weeks (several days of waiting for parts are in that time, still !!!) . But, My wife doesn't need her car every day, and we borrowed her Mom's car a coupla days - and, I've had multiple cars at the house before with my kids, the more cars you maintain, the more likely there's a broken car at any given moment. and with Lyft/Uber, one or 2 emergency transportation trips every 6 months might be cheaper than even the 'recreation vehicle' insurance and registration taxes on a 3rd car. But, having a spare car would be nice..... I can't decide how good an idea it is - ugh
just lay-out your situation to the Baja seller, ask if a few hundred dollars 'good faith deposit' would hold the car for - what? 2-3 days? if he's got paid advertising somewhere, offer to let him deduct $X for a partial ad rebate. something like that; as Don Rickles' character 'Crapgame' says in Kelly's Heroes - "make a deal!"
try to drive more 'smoothly' - train yourself look further up the road and make gradual adjustments to speed, especially acceleration. keep tires properly inflated. If you are like me and don't check them often enough - put and extra 2-3 lbs of pressure in. Make sure the tires are the same size listed on the door-card. don't drive with the roof rail cross bars installed. do not carry a bunch of tools or other gear, lighten the vehicle as much as possible. using the a/c is more efficient AT HIGHWAY SPEEDS than driving with windows down. keep windows up over 50mph if possible. no jackrabbit starts from a stop. if you are making short trips or are mostly on side streets, mileage will suffer a lot.
check engine light on? scan and report code(s) could be slipped timing - how long since timing belt system service? any dew/moisture ? could be high voltage is shorting/arcing - maybe try again when it dries-out. if you think it has spark and timing hasn't slipped - squirt some starter fluid in the intake and see if it tries to run. If it does, fuel supply could be the issue, if not, spark or timing problem?
most likely the fluid reservoir is low. Have you checked if your brother is right? It's a simple magnet and float arranfment and the float can stick or be influenced by changes in temperature or sharp turns, hard braking, vibration etc. if the float is hovering near the trip point. modern systems are designed to try to synchronize brake pad weear with fluid reservoir level. But on used/older cars this synchronization may be lost. Ideally, the fluid would me topped off at MAX immediately after all 4 wheels got new pads. still, if the brakes have not been inspected for wear recently - good idea to do that in addition to checking the brake fluid level.
03 H6 OBW got; oil&filter change, drain&fill trans, drain coolant, changed the 3 big hoses from the rad , 13 years old - seemed like they could last a few more years but, I already bought the parts - not sorry I did it. Used Zerex Asian coolant. Inspected other stuff. I might order the long hose going to the trans coil in the radiator, it has a lot of small cracks where it makes a severe bend. Wonder how much trans fluid will come out if you remove that hose?
while the car is idling normally at night with the hood up, you could spray the spark plug wires with a plant mister of water. Watch for the engine to miss and maybe see some arcing on the coil or wires. New plug wires would not be an unusual swap on any 17year old car. OEM wires only, many folks report issues with other brands.
make sure the a/c condensation drain is open and the cabin air filter is not wet or growing mold. do any passengers complain of problems? new ANYTHING can outgas vapors at first. Cars can be a little worse as they are closed-up areas and contain a lot of plastics. Perhaps an allergy/asthma specialist could test you for substances commonly found in new cars?
