105
if those wheels are 'upsized' in width, that also needs to be calculated into the issue. roughly, you want 1/2 the difference in width subtracted from the offset, so, if you are going from 6.5" 48 offset, a 7" 40 offset isn't crazy - BUT, that means the inside and outside of the rim are ~ 1/4" closer to suspension parts or wheel liners.
trouble-shooting to clear a code isn't always as easy as replacing w'ever sensor/part is mentioned in the DTC's definition. if he has little/no trouble removing them, labor should minimal - but those parts are kinda pricey to replace unless you are certain they are the cause of poor emissions/perfomance. call 2-3 shops and ask - they do enough that they will likely be within 10% of actual charges.
could be a bad rad cap - the system is supposed to hold - - what - 13-15 lbs w'ever. Maybe the cap is bad. you can buy (maybe borrow from the tool collection at the parts store) a cooling system pressure testing kit - shoul include a way to test the cap too. I've seen kits for sale at Amazon, never asked if the parts store had them to loan.
anything that says it's backwards compatible to one of the Dexron fluids should be fine. valvoline MaxLife Synthetic is what I used I think. so, Dex II, Dex III, Dex VI (?) not sure I've seen the one you mentioned. (trivia; Dexron I , except they didn't know it was 'I' at the time, anyway the first Dexron had a small percentage of whale oil in it!)
if you discovered someone has rolled-back the odometer and mismatched or otherwise fouled up some repair with the struts, how can that be Subaru's fault? your complaunt about wind noise may be deserved, there's a very well-known problem with the 'gusset' at the front of the front windows (near the mirror) http://www.ultimatesubaru.org/forum/topic/4377-drivers-window-wind-noise-fix/ http://www.ultimatesubaru.org/forum/topic/57446-wind-noise/?hl=+wind++noise&do=findComment&comment=463928 http://www.subaruoutback.org/forums/110-gen-2-2000-2004/251217-wind-noise.html http://www.subaruoutback.org/forums/110-gen-2-2000-2004/247657-excessive-wind-noise-highway-speeds.html http://www.subaruoutback.org/forums/110-gen-2-2000-2004/297977-another-wind-noise-solution-cheap-easy.html
check the 'sticky' threads here; http://www.subaruoutback.org/forums/110-gen-2-2000-2004/ put a small clamp or a coupla small zip ties on the coolant o'flow hose at the radiator nipple. the car may need it's 3rd set of spark plugs - tricky job so, stay with OEM double platinum for 60K+ miles of use. I love my wife's 03 H6 - awesome highway cruiser.
a little off-topic, but, Subaru long life 'required' or is there a Zerex or NAPA, etc. alternative?
- 10 replies
t'stat was changed with last coolant but, yeah, I planned on changing it.
- 10 replies
honestly I think coolant has been changed only once or twice so 4-6 years or so. Coolant 'looks' great.
- 10 replies
well, I asked to try to get some data points. I'm now leaning towards doing all the big hoses and the oil cooler and WP bypass hoses next April. But I'm not gonna panic if they slide a year after that. aren't there throttle body and IACV and maybe other hoses as well? what about those? It may depend on the next travel plans outta State.
- 10 replies
The Ultimate Subaru is RockAuto's Forum of the Month!
1 Lucky Texan replied to RockAuto's topic in Products for your Subaru
I saw that - cool. do we get a Certificate of Participation or ?????
