105
doubtful there's any damage - it's just that with some fluids the synchronizers 'balk' when changing gears, often because synthetic lube is TOO slippery. I have used the original fill, Extra-S and Redline LW Shockproof. The last works best for me winter-summer. Extra-S was good, but feels , I dunno - 'scrape-y' or rough in the heat of the summer. The Original fill was fine too. Most people just get a name brand NON-synthetic GL-5 in the right viscosity and go on with life. I THINK the Lucas you grabbed is synthetic so, maybe that's why you have some difficulty? But, maybe it's just that trans doesn't like that fluid? There's a HUGE thread over at NASIOC with people trying to get just the right cocktail of oils put together for their purposes/climate, etc. No one seems to ever complain much about Extra-s or Motul, well, except for Motul's price.
^^^ yeah what they said , and actually look in the radiator - don't just rely on the level on the overflow tank.
- 35 replies
- 1
- Overheating
- coolant bubbling
(and 2 more)
Tagged with:
you could pull the drain plug and inspect the magnet - 1/4 to maybe 1/2(?) teaspoon of sludeg is probably OK - chunks would be very bad. I have heard of a clutch losing one of those little springs before that made some racket - but I don't see how that would be gear-specific or 'in sync' with engine rpm. seems like some kind of input shaft issue?
well, there could be a coupla problems here I guess but, having the shop double-check their work is gonna be a good idea. If you don't trust them, have someone else take a look. sometimes the cap/o-ring on the fuel pumps in this generation of cars can develop a problem that would have symptoms similar to yours - but without the fuel leaking.
wow - thanx for getting back to us. kinda surprised the system couldn't purge itself when it cooled down - pulling coolant in from the overflow.
- 35 replies
- Overheating
- coolant bubbling
(and 2 more)
Tagged with:
how old/long since the timing system was serviced? details on engine, year, mileage, etc. the toothed idler, or the tensioner will often go bad before the belt breaks - even with 'time'. I seerviced that system on my 2006 WRX at just under 9 years of age, even though it had only about 60K miles on it - and the toothed idler was very loose and wobbling slightly, another idler was also very loose. The grease goes bad in them with time I guess. Low usage for a car is also considered 'sever duty' and that is why many items need to be serviced according to the TIME side of the maintenance schedule.
maybe slipped crank/cam timing? ECU might disable ignition if crank/cam sensors disagree?
anytime someone comes at you for that kinda money - not a bad idea to get a second opinion. Post your city in a new thread asking for a soob-experienced mechanic near your city. If the HGs are leaking externally, that kind of money will buy a LOT of fluid - just be vigilant and top-off oil and coolant as needed. many folks reduce or cure external coolant leaks with proper use of Subaru Coolant Conditioner.
could it now be flooded? Hold the gas pedal to the floor - that signals the ECU to use 'clear flood' mode and shut-off the injectors.
man - just doesn't seem like a bulb - more like an intermittent 'module' /relay ,but - has to be common to the stalk switch and the P-brake handle. The other day I could almost use the P-brake to send light the right side every alternate time I dropped it - when the light is off, it's off - when on, it seems as bright as the left side. No reduced glow or flickering. This morning - both on and repeated activation of the P-brake never turned the right-side off. They both stayed in sync. I'm gonna try to get under the hood at the bulbs at break this morning - maybe I'll spot something with the wiring......kinda reluctant to handle the bulbs and swap sides but it seems like it may be the next step.
- 5 replies
- DRL
- head lights
(and 2 more)
Tagged with:
sounds like a bad headgasket again, maybe due to a clogged radiator - or not. Since there's white vapor out the exhaust (and I bet is smells sweetish - like toasted marshmallows) I bet a cooling system pressure test would fail. the recent overheat event could also be due to a bad or failing fan - but I'd bet the shop already considered that.
Subaru Extra-S is not bad, but any NON-synthetic name brand GL-5 in the spec'ed viscosity should befine . Since the trans and front diff share the lube, it can be tricky at times getting a lube that plays well with the synchros and shifts smooth at all temperatures - seems that with the synthetic formulations, some folks say they get a little synchro clashing because it's TOO slippery.
well, looking more like a bad bulb or wiring issue now - problem didn't follow the relay. I might spring for LEDs if I can find some assurance the DRLs will work.
- 5 replies
- DRL
- head lights
(and 2 more)
Tagged with:
check the wire to the knock sensor - and look at the connector pins to see if one is pushed backwards or corroded.
- 8 replies
- Limp mode
- retarded timing
(and 1 more)
Tagged with:
every ground connection you can find - usually a few near the top of the 'bog bone' pitch stop at the firewall, sometimes some on some 'bosses' cast into the intake manifold. usualy on the fenders, etc. sometimes corrosion 'wicks' down the large battery cable under the insulation - you might check those wires. Honestly, sounds like the battery may be OK. You could check the voltage at the battery while someone else starts the car - probably shouldn't drop below 10 volts. Or, consider having it load tested at the part store - where I live, 3 years is 'old' for a battery but cooler parts of the country can get 6-8 years from a battery here's an example picture;
- 8 replies
- Limp mode
- retarded timing
(and 1 more)
Tagged with:
any signs of wiring damage from rodents or??? also, you could try refreshing some ground connections. Take 'em loose, wire-brush the various surfaces, reconnect and smear with dieletric grease.
- 8 replies
- Limp mode
- retarded timing
(and 1 more)
Tagged with:
