105
I understand there is risk - just tryoing to get some data points on quantifying it. heading to CoSpgs this weekend - hoses are 13 years old, but only 80K miles. is there a decent little kit to take in the car that might repair a pinhole leak or ? something I could grab at O'Reilly ?
crank position sensor can be intermittent with temp. Many old soobs have run with holes in the filler neck - just throws a p0440 or w'ever code. how hot is it getting though with no radiator hooked up? when it fails to start - will squirting starter fluid or brak cleaner into the intake make it fire? maybe it's a fuel problem. also, try starting with the gas pedal held to the floor - that is the clear flood procedure for flooded engine.
When did you guys experience your radiator/heater hose failures? Will those hoses last 15 years? 20 ? my wife's car is only at about 80K miles, but the hoses are 13 years old!
when you say "reset the belt" - why are you doing that? does it shift off-time?, maybe the tensioner is weak/destroyed. any CEL codes? scan and maybe a pending code will have some information. when it fails to start - does it crank? crank, and 'sputter'/try to fire?, crank and 'nothing'? maybe there is debris on the crank position sensor or the sensor is intermittent?
hmmm---if you cycle the key from OFF, to ON a few times, the fuel pump should run for a coupla seconds and fully pressurize the rails. Dot that cycle 4-5 times, then got to START. see if there's any difference. If it's better, maybe, for some weird coincidental reason, there is a fuel issue. did all the gross oil-gunk get cleaned off the plug wire boots? maybe losing some high voltage energy with arcing in there. if you think the system is flooded - try starting with your foot holding the gas pedal on the floor while cranking (don't pump) When the pedal is on the floor AND starting are detected by the ECU - it switches to a 'clear flood' mode and shuts-off the injectors. (but, I'd have expected a fuel smell from the tail pipe if it was flooded?)
I think you said, when it begins, it's repetitive? if so, is it in sync with tire rotation, or faster? Could be some carrier bearing or u-joint problem i guess. you feel no jerking or binding when maneuvering or parking in parking lots? maybe after it happens, you could measure hub temps with an infrared thermometer - if a bearing is failing in an odd way, that hub may be hotter than its mate.
post your city in a new thread asking for a mechanic - maybe someone can suggest a shop that will track down the noise. If you can duplicate the sound for a mechanic on a test drive, that will help. a common source for banging is the sway bar and its link/mounts. They can also be broken and will catch and pop. Plenty of other sources of noise of course, even springs can be broken in odd ways.
brakes are common wear item for all cars. knock sensors are $10 from ebay axles are a common repair for most cars too - not horribly expensive to replace or re-boot O2 sensors can be a little pricey - but, some codes for that are just an exhaust leak - some welding could be all that's needed get a new one, keep this one too! (man, I wish I could get it)
no - I doubt you're an idiot - but I can tell you whoever approved the iconography on our 03's stalk was, it clearly indicates washer-squirting with a pull of the stalk, but all you get is a quick mist-wipe. the ONLY way to get front washing is the button on the end. I THINK I've seen a thread about modifying the swith's little pc board to alter the function. Not worth the trouble to me.
get new KYB - I just don't think junkyard struts would be much better than the ones you have - I suppose if you found some with less than 50-75K miles, maybe..... you can scribe the position of the adjustment bolt and get camber back close enough. do a search - you can find DIY stuff here and over at subaruoutback.org , as well as some youtube videos (users ericthecarguy and briansmobile often have Subaru videos that are good). check parts prices at Amazon, RockAuto, etc.
