1 Lucky Texan
    105
  1. maybe someone knocked the nub off, then returned them for refund - and you got them as new? do you recall anything unusual about the packaging? Once, I bought some wiper blades that were supposed to have been new, but they had used blades in the package! I also know someone who (years ago) bought used oil - new off the shelf at a walmart! (I always inspect the ring or inner seals now when I buy fluids)
  2. fairtax mentioned the rear bushing for the lower control arm - I also think it needs inspection. also, could someone pace the car, each of you have passeneger/observers on cellphones so the pace car could know when to circle your car when the vibration happens? maybe they could spot some wheel hop or other visible problem. just to be clear, this is a repetitive noise that seems to begin above 60 but varies with speed? do you also feel vibration? seat of the pants, or in the steering wheel? any 'jerkiness'/bucking in the car?
  3. assuming all sensors are working normally, the ECU can adapt to changes in fuel in a coupla drive cycles.
  4. were the plugs gapped before installation? very easy to damage the little iridium 'nub'. NGKs come pre-gapped and any use of a gapping tool 'could' have damaged those 2 plugs.
  5. I'm not sure lye would be safe on aluminum - maybe heavy castings would be OK, not sure about sealing surfaces. They may etch.
  6. Hmmm - I don't think the binding would go away if the discs were hung-up on a grooved 'basket'. has the trans or rear diff been swapped on this car? any cel codes? pending codes?
  7. oh, gotcha make sure to get the 'real' OEM style filter - it isn't built the same as an engine oil filter.
  8. I always check Amazon and RockAuto, there may be slightly cheaper sources, but probably none with better reputations for customer service.
  9. my 2003 doesn't have it - it has a 'remote location' behind the fog light. Dunno about an '08, but maybe it's somewhere else? most people say it's a 'life of the car' item. I wouldn't change mine unless I opened the case of the trans or maybe if incorrect fluid had been put in my trans.
  10. you could dig around at www.opposedforces.com , but maybe someone else will reply with experience on this.
  11. I think at one point on my car, I had to use my scissor-jack to push the control arm down? I THINK - it's been a while. maybe read here; http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/16297-rear-shock-replacement-2000-outback-wagon.html http://www.ultimatesubaru.org/forum/topic/146578-trying-to-get-a-rear-strut-back-into-my-subaru-legacy-1999/
  12. hmmm - inner tie rods may be very worn - I could see them worn enough to possibly clunk, just not repetitively with tire rotation. But, they would directly affect toe. On a 99, many suspension/steering parts could be worn. rear bushing for lower control arm, strut bearings, sway bar mounts/links. maybe take your mechanic for a test ride and demo the problem for him?
  13. lines to the cooler in the radiator? - thise might not be pricey to replace. Still, kinda wonder how much of the remaining lifespan of the trans was sacrificed when it lost the fluid.
  14. spline count , compressed free-length, and tone ring if applicable would be the 3 main factors.
  15. I'm not sure - I know 'limp mode' on the turbos cut the boost. maybe it limits rpm on the na models? VSS will cause problems but, seems like you already have this bypassed? guesswork again. can you scan the ecu for pending codes?
  16. that lack of additional codes may be another symptom of 'limp mode' but it's just a guess on my part. most 95s were already OBDII I think. even though it wasn't required until 96.
  17. folks swap in transmissions often. just confirm the final rive ratio is the same as stock. (must match FD of rear diff) LKQ and car-part.com are some comon sources
  18. well, I CERTAINLY am no expert. maybe some ECUs are fine because they revert to a base map that is 'close enough' ? hopefully, someone will chime in with 'swap' experience. If not, try checking at NASIOC.
  19. yeah - MAP sensor is gonna be critical. either the car is in 'limp mode' without it - or the A:F ratio is too far out to run.
  20. maybe several small issues - all working against you. oil may be diluted with fuel - so, it runs off the rings quickly. what weight oil are you using? have you tried a heavier grade or one of the high mileage oils? I suppose, to help prove the problem is the rings, you could pull the spark plugs and find some way to spray oil into each cylinder after it has sat long enough to exhibit the problem. Then see if it behave the same way.
