105
maybe someone knocked the nub off, then returned them for refund - and you got them as new? do you recall anything unusual about the packaging? Once, I bought some wiper blades that were supposed to have been new, but they had used blades in the package! I also know someone who (years ago) bought used oil - new off the shelf at a walmart! (I always inspect the ring or inner seals now when I buy fluids)
fairtax mentioned the rear bushing for the lower control arm - I also think it needs inspection. also, could someone pace the car, each of you have passeneger/observers on cellphones so the pace car could know when to circle your car when the vibration happens? maybe they could spot some wheel hop or other visible problem. just to be clear, this is a repetitive noise that seems to begin above 60 but varies with speed? do you also feel vibration? seat of the pants, or in the steering wheel? any 'jerkiness'/bucking in the car?
I think at one point on my car, I had to use my scissor-jack to push the control arm down? I THINK - it's been a while. maybe read here; http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/16297-rear-shock-replacement-2000-outback-wagon.html http://www.ultimatesubaru.org/forum/topic/146578-trying-to-get-a-rear-strut-back-into-my-subaru-legacy-1999/
hmmm - inner tie rods may be very worn - I could see them worn enough to possibly clunk, just not repetitively with tire rotation. But, they would directly affect toe. On a 99, many suspension/steering parts could be worn. rear bushing for lower control arm, strut bearings, sway bar mounts/links. maybe take your mechanic for a test ride and demo the problem for him?
maybe several small issues - all working against you. oil may be diluted with fuel - so, it runs off the rings quickly. what weight oil are you using? have you tried a heavier grade or one of the high mileage oils? I suppose, to help prove the problem is the rings, you could pull the spark plugs and find some way to spray oil into each cylinder after it has sat long enough to exhibit the problem. Then see if it behave the same way.
