105
i'd check timing - probably OK. if no fire with ether, could be a no spark issue - especially if the car turns over with what 'seems' like normal compression (this "Rrrr,Rrrr,Rrrr,Rrrr" repeated. and NOT either ; "rrrrrrrrrrrrrrrrrrrrrrrrrrr" fast, nor, "Rrrr,Rrrr,reeer,Rrrr" with one fast like a dead/low comp. cylinder so, basically severely messed-up timing or , no spark. I suppose an intermittent, now bad, Crank Position Sensor is possible.....
seems unlikely the system could pull enough timing to cause as severe a problem as you have - but, changing the knock sensor is cheap and easy - may relate to the prev. problem of pinging. scan again for codes - might be a more-useful 'pending' code. try a squirt of starting fluid or brake cleaner to see if it fires. 'dropped' valve guide might cause a severe but intermittent problem - they can shift back and forth...vacuum test might spot that.
maybe some size 12-pt socket of appropriate size - that is, slightly too small to drop over the plug, could have the 12 'points'/'lobes' filed/ground to create an 'entry' or ramp - on each lobe. Them, hammer it onto the plug. Might grip well enough to extract the plug. This is similar to how thieves defeat security lug nuts.
I had a similar issue with my WRX, almost 9 years old, but under 60k miles. I changed all the pulleys , kept the waterpump, kept the cam and crank seals. Ebay kit from, I think , mizumoauto. (may have been theautoexperts ? - I looked at several sources). I got a mitsuboshi belt in my kit. I would trust gates as well. glad I did it. my toothed idler was very loose and wobbled a little. another pulley was very loose.
I re-read the thread - does it seem to only happen after the car warms up? wotdsm mentioned the coolant temp sensor (might be one 3 wire device onyour cat, if not, it's the 2 wire one, not the single wire temp gauge sender. anothet thought, hook a vacuum gauge up and see what it does before and after the problem exhibits itself. Maybe a valve is sticking or ....?
look inside the PS tank closely while idling - if there are bubbles - you have an air leak. lots of info, search air - power steering - o-ring , etc. bearing in tensioner pulley - or the pulley's mount, might be throwing/snapping belts? also, watch crank pulley for wobbling while running - it's 2-piece and the rubber ring can fail.
