1 Lucky Texan
    105
  1. i'd check timing - probably OK. if no fire with ether, could be a no spark issue - especially if the car turns over with what 'seems' like normal compression (this "Rrrr,Rrrr,Rrrr,Rrrr" repeated. and NOT either ; "rrrrrrrrrrrrrrrrrrrrrrrrrrr" fast, nor, "Rrrr,Rrrr,reeer,Rrrr" with one fast like a dead/low comp. cylinder so, basically severely messed-up timing or , no spark. I suppose an intermittent, now bad, Crank Position Sensor is possible.....
  2. seems unlikely the system could pull enough timing to cause as severe a problem as you have - but, changing the knock sensor is cheap and easy - may relate to the prev. problem of pinging. scan again for codes - might be a more-useful 'pending' code. try a squirt of starting fluid or brake cleaner to see if it fires. 'dropped' valve guide might cause a severe but intermittent problem - they can shift back and forth...vacuum test might spot that.
  3. meh - if you used the recommended NGK plugs, they actually warn against using anti-seize. I wouldn't pull them. crush washer already crushed and the more you handle them, the more likely to bend an electrode or crack porcelain.
  4. maybe some size 12-pt socket of appropriate size - that is, slightly too small to drop over the plug, could have the 12 'points'/'lobes' filed/ground to create an 'entry' or ramp - on each lobe. Them, hammer it onto the plug. Might grip well enough to extract the plug. This is similar to how thieves defeat security lug nuts.
  5. I THINK (not certain on this engine) they are 'shoulder bolts' and not 'typical' at all.
  6. lots of info here; http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/43428-diy-c-air-conditioning-leak-refrigerant-repair-5-less-15-minutes-less.html easiest is often as said above, (if repairs have been made and the systems is empty) put in the volume the system requires.
  7. good posts timing belt system is a priority. another sensor worth investigating is the knock sensor - but symptom more closely matches engine temp sensor.
  8. My wife wants a new (well, different) car badly. But I really doubt I will be able to let her Outback go. So, kinda wondering about having 3 cars myself.
  9. there's also this; http://www.subaruoutback.org/forums/110-gen-2-2000-2004/297977-another-wind-noise-solution-cheap-easy.html
  10. did it smell like toasted marshmallows or like oil? any fluids low? any chance the smoke was drifting up from lower dow, near the exhaust?
  11. I had a similar issue with my WRX, almost 9 years old, but under 60k miles. I changed all the pulleys , kept the waterpump, kept the cam and crank seals. Ebay kit from, I think , mizumoauto. (may have been theautoexperts ? - I looked at several sources). I got a mitsuboshi belt in my kit. I would trust gates as well. glad I did it. my toothed idler was very loose and wobbled a little. another pulley was very loose.
  12. I have read several posts of people having to replace leaking lines that run over the gas tank. I think the use the old line to pull the cupronickel (?) replacements through?
  13. http://www.subaruoutback.org/forums/110-gen-2-2000-2004/41182-symptoms-fuel-pump-o-ring-problem.html
  14. check voltage too - ABS seems most sensitive to charging/battery problems on some older cars.
  15. I re-read the thread - does it seem to only happen after the car warms up? wotdsm mentioned the coolant temp sensor (might be one 3 wire device onyour cat, if not, it's the 2 wire one, not the single wire temp gauge sender. anothet thought, hook a vacuum gauge up and see what it does before and after the problem exhibits itself. Maybe a valve is sticking or ....?
  16. yeah, I even read of a guy getting misfires due to debris on the crank position sensor - cleaned it off and the car ran fine.
  17. look inside the PS tank closely while idling - if there are bubbles - you have an air leak. lots of info, search air - power steering - o-ring , etc. bearing in tensioner pulley - or the pulley's mount, might be throwing/snapping belts? also, watch crank pulley for wobbling while running - it's 2-piece and the rubber ring can fail.
  18. I think some people have replaced the switch at the brake pedal - or a plastic 'button' that contacts it.
  19. can you or your mechanic get you eye close to the top of the open PS fluid tank You need to look for foam/bubbles while idling - maybe as someone works the wheel back and forth. example;
  20. wonder if the mechanic scanned for codes? sometimes, there are 'pending' codes and the CEL may be dark. was the timing belt systems serviced at 105K miles? I'd hope a mechanic would look for skipped timing.... I think some 06es have had gas pedal problems. Not sure your symptoms fit.
