1 Lucky Texan
    105
  1. pretty sure you had some atypical oil usage - not every 2.2 is gonna do that under 'normal' circumstances. isn't there a seal on the oil return into the pan that can cause oil consumption problems? or maybe when the conversion was done, there was some confusion about breather/PCV hoses? CCR in Colorado might have some parts for you - or check LKQ and car-part.com for engines, maybe craigslist for someone parting-out a car. the frustration comes thru in your post, I just have generic suggestions....sorry
  2. starting in 06, the 5 spds in the WRX had a little shorter shifter, and a better 1st gear synchro - maybe other improvements? that might be a good trans to put straight-cut gears in. consider lighter flywheel and lightweight crank pulley too - 4lbs of rotating mass = ~1hp. anyway - sounds like a fun project! way above my skills
  3. some discussion of modified gearsets; http://ppgearbox.com.au/page.asp?parentid=2&parent2id=14&parent3id=26
  4. if this progresses to an unrecoverable state - you might have a 'Plan B' where the original mount point is blocked-off (tig welded over?), and you can get an oil sender adapter to fit under the oil filter. Of course, splice in some wiring to re-position the sender down there.
  5. you could put dogtooth gears in at 1 and 2 I think there are sometimes labels on TOP (convenient huh?) of the diffs that help differentiate them. might be some good info for you over at NASIOC too.
  6. kinda seems like either the battery's post is intermittent in the case - or possibly you have a cable with a lot of corrosion under the insulation.
  7. trans stick is on the right side near the firewall, down kinda low. when the steering feels odd - or there is some squealing from the pump - look inside the PS fluid tank for foam/bubbles.
  8. CV joints definitely go bad regularly enough - but so do wheel bearings. any work done in the last few weeks? is the sound central or left or right? checked the trans fluid level? use an infrared thermometer and compare hub temps L to R after a highway run. If one side is consistently hotter - maybe a bearing?
  9. uh - TWO tires? are your tires now all 4 the same size/brand/model and near each other in wear? they should be.
  10. I think a potentiometer or a small resistor network can be used to kill the code too. Just something adjusted to send - what? ~0.7V back on the sensor wire?
  11. it may have something to do with cylinder scavenging or 'yaw' vibration/oscillation or ????? flat 4 boxer engines eliminate one entire set of vibration harmonics that plague in-line 4s anyway so, I'm guessing they have a good reason. check the graphs on page 15 here; http://www.surrealmirage.com/subaru/files/SAE_boxer.pdf
  12. the only theory I have read about it, was that the 2.5 open-deck jugs just 'move around' too much for th 'old style' HGs.
  13. (I always wondered if anyone modded a soob engine into a 'big bang' motor - kinda doubt the crankshaft would last long.) I think this is how our engines fire;
  14. find one with blown engine, build an engine for it with turbo (mls) gaskets. Be prepared for rod knock if you don't rebuild to the bottom end. Might get lucky and overheat was minimal.
  15. Discount Tire will match (after tax and shipping calculations) Tire Rack prices. Look at some Kumho tires - good value.
  16. check www.cars101.com for cabin air filter instructions across several mode/years I like have our vacuum cleaner with small nozzle attachment ready when I do ththat filter service, just to clean-up the area as best as I can reach.
  17. have used it for that a few times - works well. It can work well to remove sticky adhesive residue from labels, etc. too. have to follow up with a household cleanser usually.
  18. leakdown test might show leaking exhaust or intake valve. smurfsack - how many miles on the engine? a used engine from a wreck could be an option - might have 1/2 the mileage. LKQ or car-part.com ,not cheap, but an idea.....
  19. if you don't KNOW the timing belt system was properly serviced, maybe a loose tensioner is letting the belt flap around too much. that's an interference engine, don't drive it without KNOWING the condition of the TB idler pulleys and other parts. should be serviced every 105K miles OR 105 MONTHS, w'ever comes first. The toothed idler can seize or puke its bearings - throws the belt off.
  20. might be a switch at the clutch pedal - maybe mouse chewed wiring.... neutral safety switch problem of some type.
  21. was the parking brake engaged? maybe it was and you backed-off the star wheel to remove the rotor???? seems like u would recall disengaging the handle afterwards though. weird
  22. looking at a MSDS for that product - there's very little lube in it (1% - 5%); 3 - Composition/Information on Ingredients Ingredient CAS # Weight Percent US Hazcom 2012/ GHS Classification LVP Petroleum Solvent 64742-47-8 60-80 Aspiration Toxicity Category 1 Poly(dimethylsiloxane) 63148-62-9 1-5 Not Hazardous http://www.wd40specialist.com/pdf/WD40SpecialistSilicone Lubricant-MSDS(6-24-11).pdf http://www.wd40specialist.com/pdf/WD40SpecialistSilicone%20Lubricant-MSDS(6-24-11).pdf
  23. ah - looks like a different product. Not sure how it differs from other silicone sprays.
