Best Subaru engine?
1 Lucky Texan replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX'best' might depend on your intended use. dunno if we have enough time on the FB engines to determine possible longevity. how have the diesels been holding up overseas? Kinda wonder about my 06 WRX's engine. (of course, many are 'tuned' , raced or abused) it seems to not have the oil screens, it does have a water cooled turbo bearing. of course, turbo HGs ... how durable will it be with somewhat 'normal' driving?
Knocking from right front end. Tranny, CV, ?
1 Lucky Texan replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXexhaust hanger?
I'm new too the subaru
1 Lucky Texan replied to cnndad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrun stickier tires shed weight - lightweight crank pulley and flywheel, lighter rims(maybe not for rally cross) , take out seats, etc. approx 1 hp for every 11 pounds of mass, 1 hp for every 4 lbs of rotating mass. make certain you arent' riding on worn out struts or other suspension/braking bits.
1997 EJ25 Cylinder Inspection
1 Lucky Texan replied to raindawg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcoin toss but - I'd be tempted to find an engine from a wreck (might have half the miles and no overheat events, still would need gaskets and TB though) to rebuild - or drop a 2.2 in the car.
- 2 replies
- head gasket
- overheating
- ej25
- warp
Tagged with:
CEL code: P0171
1 Lucky Texan replied to Wallis_93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd want to inspect the fuel pump's cap and o-ring could be anything that throws-off OR confuse the ECU about A:F ratio. MAP, front o2 sensor, vacuum leak.....
97 Legacy, EJ22, miss at idle, misfire cylinder #4
1 Lucky Texan replied to battleborn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmaybe a dropped valve guide? they can even shift around if loose I think.
typical inexpensive shop lights put out a lot of green/'cool' light. whitebalance will help , not sure if that's an option on a phone or even all digital cameras.
HELP! check engine light blinking
93 huh - some older soobs had intermittent crank angle sensors - but they would usually fail 'hard' when warmed up. (uh - 93 doesn't have a disty right?) does it have a MAF - those sometimes are intermittent. maybe tap on it and see if there's any change in idle? might need a cleaning too?
well, one possible test for fuel starvation might be to spray some carb cleaner into the intake when it is stumbling/missing. If it seems to smooth out - could be starved for fuel ? kinda wonder what the plugs look like and if they all look the same.
Frigid weather--rough ride?
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsome tires might be less compliant I guess. In the 'old days' nylon belted tires would even take a 'set' and would bump for a few minutes. but, I'm a southern flatlander so - yeah, snow packed in the suspension sounds bad.
1 Lucky Texan replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXum - make sure the stub axle didn't pop partway out?
not much for an exhaust?
I assume you mean just for a few weeks? I doubt there would be any permanent damage - but I have no experience doing it. from what i've read, generally speaking, you want a smooth, equal-size internal path to propagate the pressure pulses - it aids in cylinder scavenging and helps with low rpm power. Changes to larger/smaller diameters or odd shapes can cause issues.
Strange Issue with 1995 Subaru WRX
1 Lucky Texan replied to snhall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany diagnostic codes stored? some older MAFs get intermittent - that might throw the a:f ratio so far off to choke the car. doubt EVERY injector is bad - doesn't mean the ECU isn't confused and keeping the injectors open too much - intermittently.
what impreza should i go for
1 Lucky Texan replied to Skyr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe risk with turbos - while never zero - goes down quite a bit if they are; A. never associated with a person who abused the car (racing, 'tuned', 'teenagers' ,etc.) B. have been well serviced C. Low-ish miles . But, you would want to ASSURE yourself that it's good buy - as said, turbo or turbo seal failure is gonna be expensive. AT LEAST have a reputable Subaru-experienced mechanic drop the pipe and inspect the turbo's shaft play and look for leaking seals.
Power Steering
1 Lucky Texan replied to Kacie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoriginal belts are 'probably' getting old for most of us at 60K miles or so. Start with belt replacement and go from there. Get Gates or similar quality - on stuff like belts, brake pads, etc.('consumables') , never ask for the cheapest the store has, it won't last long.
Power Steering
1 Lucky Texan replied to Kacie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow does the belt look? how many miles?
Atf temp light
1 Lucky Texan replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould be - check ATF level when warm while idling(good idea to run it thru the gears with foot on brake first) - if not idling, it will show high.
Power Steering
1 Lucky Texan replied to Kacie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot sure I follow, did you SEE bubbles before? anyway, if air in the system is not the problem, then the belt or possibly the crank pulley are suspect. 2011 may have those stretch belts - if the belt has been changed - was the correct type installed?
Atf temp light
1 Lucky Texan replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpossible broken ATF pump. If the TC slipped forward, then, if you use the bolts to pull the case up the last 1/2 inch or so, the pump can be cracked.
1995 Legacy Wagon - Fuel Smell @ Start Up
1 Lucky Texan replied to mcnea001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXengine temp sensor may be bad - pretty sure on your car, it is a separate unti from the gauge sender - look for the 2-wire one on the crossover pipe. it may be bad - keeping the car in 'choke' all the time.
1999 security reprogram troubles
1 Lucky Texan replied to provin1327's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou may need to swing by a dealership when they aren't too busy and see if a salesman would do it for you - maybe offer him a coupla lottery scratchers if he's successful? I don't know if there's a big difference from your model, but I had no problem doing it 2-3 times in my wife's 03. does the horn work? Make certain the security system is not enabled. (cycle key 3 times quickly if not sure) make sure you are going past ACC to ON (but not start) , and back past ACC to LOCK (off). I THINK you have to have a ffoot on the brake pedal too so, if the brake pedal switch were bad - it may not work.
2008 Outback Tire Pressure Monitor system Question
1 Lucky Texan replied to gregB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXvery brief glance at a few websites yields a rule of thumb close to - a drop in temp of 45-50*F ill cause a drop in tire pressure of about 4psi. So, if you were in the middle of the 'range' - temps only need to drop 25*F or so to trigger the light. http://www.tirerack.com/winter/tech/techpage.jsp?techid=73
1 Lucky Texan replied to gregB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've been happy using a 78% Nitrogen mix.
1 Lucky Texan replied to gregB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdunno the thresholds/hysterisis you're fighting physics when the temp drops a lot; https://en.wikipedia.org/wiki/Ideal_gas_law
1 Lucky Texan replied to provin1327's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have had 2 of the remotes for our 03 OBW go bad. They would work sometimes if I 'pinched' them in the center while pushing buttons. Sometimes the red light would stay on dimly....replacements from a Forum and one from ebay are what I'm using now.
