105
2 of those codes point to a problem with the O2 sensor (front or 'main') and the 0340 is a cam position sensor. You may have more that one problem but, with the cam pos code - one more reason to triple-check cam/crank timing. If you smelled something sweet - like toasted marshmallows, in the exhaust - I suppose it's possible a coolant leak nto a cylinder led to 'poisoning' the O2 sensor. I hope someone else with more experience will chime in. i suspect you will need to pin-down whether or not you have a headgasket leak or some odd way coolant is getting into the exhaust (sometimes, pulling plugs and comparing will find the bad cylinder as the coolant makes the plug look different). If that isn't addressed , you might destroy the next O2 sensor. Worth looking for wiring problems too - pinched or chewed cables or bad ground connections will sometimes cause multiple codes to be set.
could the rad fans be intermittent? When it overheats, are you cruising down the road or does it always happen at a stoplight/railroadXing/idling? bad fans will allow overheating at a stop or very slow speeds - on the highway - air is moving thru just fine. you might be able to 'map' the radiator with an infrared remote therm - maybe the radiator has cool areas because it's partly clogged. how old is the timing belt? maybe the car has slipped a tooth and is not running at correct crank/cam timing - or the back-side of the belt is glazed and the WP is slipping?
we have an 03 chains are supposed to be the life of the car there are beginning to be more HG issues mentioned - not sure if the RATE of problems is approaching the 4cyl. the engine is glass smooth and has great highway passing power - a little 'doggy' off the line. - probably like any typical 6 cyl. some say that valve clearances might be tight at 200K miles (exhaust valve particularly). we like ours overall. not many miles on it but - I like driving it still. there are some well known, 'fairly' minor common problems; (acc belt pulley bearings)
I see where some Acuras and Hondas can get a start (maybe only one?) even if the transponder is absent. The brake pedal is used to enter a vin-specific code. anything like this on newer soobs?
waterpumps on our cars are exceedingly reliable, I didn't swap mine out when I did my first TB service on my WRX. but, I will probably accelerate the next service by 10-20% . You might consider just the tensioner, rollers and belt unless they see oil seepage - then add the cam/crank seals. Save the WP and re-sealing the oil pump back (GG - is this still needed on cars as new as 07 ?) for the next service.
it needs a timing belt system service now/soon. (105K miles OR 105 MONTHS) But that sure seems like a steal! You might even show her a dealer estimate for the timing belt service to bargain it down a little more. think of it this way - the money you save over the typical price paid in your area for a similar car will pay for a lot of gasoline!
well, yes the disconnect likely caused the system to run from the factory map and monitors are trying to complete and adjustments are being made to a:f and timing. Surprising though that the car stalled. Is the CEL on? Could the work with the battery cables have caused the problem? triple check that connections are tight and no hoses near the battery and batt. cables were knocked loose. if there is a concern the cd changer is a parasitic load on the battery, you might consider pulling the fuse for its circuit. (on some older models, a stuck CD can drain the battery)
I doubt it's gonna help since you are getting spark and it's cranking - but you could try a coupla lock/unlock sequences with the key fob in case the security system is confused.
- 5 replies
- engine swap
- used motor
(and 1 more)
Tagged with:
maybe spritz some carb cleaner in the intake while cranking to see if it fires. Check fuel pressure? does exhaust smell like fuel? if you pull a plug and it's wet, put it back and try cranking with the gas pedal on the floor - that is the clear flood routine for the ECU to shut off fuel. you timed the crank pulley using the dash on the tab at the back? NOT the triangle/arrow on the front right?
- 5 replies
- engine swap
- used motor
(and 1 more)
Tagged with:
IACV hose may have dropped off the intake tubing. Not sure though - and may not explain the rich condition.... odd, I'd triple check everywhere I worked, everywhere they poked around during the test for hoses or wire connection loose - including grounds. might be worth checking cam/crank timing. did you scan for pending codes?
kinda wondering about loose/corroded grounds and perhaps robent-chewed wires. Certainly, an older car could use some attention to ground connections - take 'eme apart, wire brush all the surfaces, reconnect and maybe coat with dielectric grease. do you still have a check engine light? what codes are being posted?
