105
How to verify mechanic (corporate shop) destroyed my engine
1 Lucky Texan replied to Todd Toddman's topic in Shop Talk
maybe you have incorrect sized tires and/or the transmission was swapped from a vehicle with a different final drive ratio. Odometers are usually 'rolled back' (total mileage reduced) but that is not going to affect the rate of accumulation.- 26 replies
- 1
- oil pan gasket
- oil pan
- (and 4 more)
TPS signal dropping out? Maybe get an analog meter on the tps output and exercise it to see if resistance change is smooth.
what they all said up there. Do you KNOW the car got a proper timing belt system service? You could always accelerate the timing belt system's service schedule. Do it at 75K miles or 75 months for instance. Make darn sure you are using a good kit. Don't run without covers. Use good oil, make sure the turbo and avls oil screens are clean. buying a used turbo is a gutsy move. If you want to worry about something, read about the Killer B oil pick-up .
- 6 replies
- ej25
- non-interference
(and 1 more)
Tagged with:
check underhood along the plastic tank - to - metal core attachment. It's a common leak point. You could get a pressure testing kit from a parts store on loan to help too. Be aware, many folks have slowed/stopped minor leaks with the Subaru Coolant Conditioner. I'd want to make darn sure the heater core had to come out before tackling that job. (sry to hi-jack with no info on the swap itself)
auto right? be sure to get/order the correct style radiator.
- 28 replies
- 2.2l
- engine swap
(and 2 more)
Tagged with:
Kkeke from Belgium, Europe
1 Lucky Texan replied to Kkeke's topic in Meet n' Greet. Your USMB Welcome Center
wow, welcome to the Forum! -
1971 FF-1 - Back from the dead?
1 Lucky Texan replied to Subaru_GL's topic in Historic Subaru Forum: 50's thru 70's
man, kinda lucky the glass looks all good. fun project -
oh, sorry, COOLANT leaking now, not oil. maybe 'rent' a pressure testing kit from the parts store.
- 105 replies
oil cooler adapter seal is quite likely. Leaks a lot too. Easy to fix with the correct deep socket - 24mm. the one for my 03 H6 was under 8 bucks - 21370KA001
- 105 replies
well, one possibility is the little foam gaskets on the blend doors are failing and draggging or getting 'bunched-up' in some way. I have even had older cars 'spit-out' pieces of foam from the vents. But, I have no idea if failures like that in Texas would be common elsewhere. Heat here is brutal on many plastics and rubbers.
