105
not sure where you are reporting the wetness, but I put small zipties to act as clamps on the little overflow tube at the nipple on the rad neck because I saw coolant under it on one car, and the other one's tube was stiff and didn't feel like it was sealing well. Under normal circumstances, I don't think there should ever be much over atmospheric pressure in that line - but I have seen dripping - and other cars have it clamped. To me, it seems likely air could be pulled in, in place of coolant in the o'flow tank - leading to a low radiator over time and a somewhat normal level in the o'flow. And who knows what happens if you couple the above with an old radiator cap and dirty o'flow tank?
I have Subaru SPT 'pinks' on my 06 WRX - and those are notably harsher than the stockers. old struts might have less rebound damping, but their downstroke would also be looser, not harder than new. Also, don't some folks need to cut about a third of the bump-stop off? maybe that wasn't done....not sure about that though. just depends on exactly what you are experiencing but, (other than correcting track/height issues mentioned above) i doubt new struts SOLELY will improve the problem and likely will make it slightly worse.
you could try re-registering the fobs using instructions in the manual or over at www.cars101.com (not sure but, car might be in an odd mode like Valet ?) I have bought used fobs and registered them - it worked. before i replaced them, I found that squeezing them with one hand while pushing the button seemed to help. But, that was with 03 Outback style so.....
from the Permatex site - under the 24110 number's instructions, it says in bold "DO NOT APPLY TO BRAKING SURFACE OF CALIPER PADS OR RUBBER SURFACES." http://www.permatex.com/products-2/product-categories/specialized-maintenance-repair/brake-maintenance-repair/permatex-ultra-disc-brake-caliper-lube-detail So, the 'green' label stuff is known to be bad for rubber. DO NOT APPLY TO BRAKING SURFACE OF CALIPER PADS OR RUBBER SURFACES. - See more at: http://www.permatex.com/products-2/product-categories/specialized-maintenance-repair/brake-maintenance-repair/permatex-ultra-disc-brake-caliper-lube-detail#sthash.nL4uuM2p.d DIRECTIONS: 1. Clean all caliper parts to be lubricated with Permatex® Brake & Parts Cleaner. 2. Apply Caliper Lube to pins, slides, bushings and pistons. 3. Lubricant may also be used as a noise suppressor to eliminate caliper brake squeal. DO NOT APPLY TO BRAKING SURFACE OF CALIPER PADS OR RUBBER SURFACES.
fair - I wish I understood where the problem is. Even in the reviews at Amazon, you find an entry or 2 blaming the permatex for affecting rubber. maybe there was a few years where the compound Subaru used was the issue? I dunno. the bottle I have now is this I think; And, in the few times I've used it so far, doesn't seem to have caused any problems. with an 06 Impala, an 03 Outback or an 06 WRX. I use it everywhere I think there could be sliding or contact.
http://www.amazon.com/dp/B0091KCG0W/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=IDEFQ97CY9SH&coliid=I11ZL9W8SL2MQD&psc=1 afer reading that the permatex can cause our soob brakes rubber parts to swell/degrade (not tested or experienced by me personally) I think I'm gonna switch to the above Silarmic. most recently read here;http://www.subaruoutback.org/forums/81-wheels-tires-brakes-suspension/291250-brake-grease-lesson.html
Honda element problem; http://takakiauto.com/blogs/kunio/emission-fail-spider COOL - please let us know what you find OK?
- 12 replies
- gas tank
- filler neck
(and 2 more)
Tagged with:
it's a little ATF fluid. cover the belt and surround area with a rag or 2, lift the adapter/hose up so it doesn't spill much, replace o-ring(s) , reassemble, top-off fluid wit Valvoline MaxLife dex/merc or similar. clean the area. our cars will clear the air out very quickly, 2-3 trips to full lock, L to R. Just montor after that. if you still have bubbles - could be a cracked hose or fluid tank. PS pumps do fail, but ti isn't common. your mechanic could probably do this for you for - what? - $25 to $40 dollars.
maybe some Berryman's B-12 or BK44 w'ever in the tank would un-stick any stuck components? def. look for signs of insect activity in the ends of the evap hoses in the back. read this! ;http://forums.nasioc.com/forums/showthread.php?t=2554768 good luck
- 12 replies
- gas tank
- filler neck
(and 2 more)
Tagged with:
def. check the radiator level - safely, when the engine is cool. actually look in the rad - don't trust the overflow bottle. not sure from how you are describing the sound - could this be a slipping accessory belt? or, does it really sound like a fluid? maybe open the hood and have someone else start the car and listen. If it's louder inside the car, could be something with the coolant, a/c or fuel tank. If it's louder under the hood, maybe a slipping belt or.....? also, next morning before starting, remove the gas cap. note any pressure in there, start the car.
