105
I have read about these issues extensively. (and, my MIL's 2011 Forester had to have the tank replaced for this!) there are at least 2-3 ways this can happen generally, with 4-5-6 causes. one thing to ask your customers - and they need to be honest to help with diagnosis - do they 'top-off' when they fill the tank. The charcoal canister can become flooded to the point it weighs pounds more than normal and blocks proper venting. the evap 'drain' hose could be clogged - it actually can allow air/fumes to travel in 2 directions depending on system requirements. But, if insects or mud has clogged the hose's outlet, it may lead to a problem like slow filling. If a bad attempt at siphoning fuel was ever made,if the filler neck is rusted in certain ways, that can cause issues. if certain evap solenoids/valves are bad, that can cause issues. if a car sits unused for a long time, the tank's vent valves can stick. some people just live with the problem, some have discovered that rotating the pump's hand 45*s to the side when filling helps. it's crazy.
- 12 replies
- 1
- gas tank
- filler neck
(and 2 more)
Tagged with:
you might consider something like a Perrin lightweight pulley. http://www.ebay.com/itm/Perrin-Performance-Red-Crank-Pulley-Subaru-WRX-STI-2002-2013-/301186148305?fits=Year%3A2001|Model%3AImpreza&hash=item462017e7d1&vxp=mtr
- 7 replies
- 1
- crank pulley
- crankshaft pulley
(and 1 more)
Tagged with:
is the vibration felt throughout the car or just in the steering wheel? any change if you coast in N ? is the noise a whine, growl, hum or a rattle or a buzz....what?
- 10 replies
- drive-shaft
- drive-shaft bearing
(and 2 more)
Tagged with:
people have done all kinds of swaps - probably 'easier' (this is a relative term, it won't be 'easy') to swap in engine and probably driveline gear from a wrecked WRX. over at NASIOC I'd bet you could find threads on a similar swap. you can do almost anything with enough $$$$$ - cardoc SUPERcharged a 6 cyl. Outback! you just need to pick the path that best fits your budget, mechanical ability, tolerance for being without your car and dealing with a lot of details - and your goal.
if you really beat-up the brakes, make sure to run stickier tires, consider StopTech Street Performance pads. They are an affordable upgraded pad with high MOT but they bite when cold and modulate well. They will dust more though. (yeah, you could run Hawk, Carbotech or Ferodo, etc. - but they are even more money)
I think in years across 3 Forums I have only read of 'chocolate mousse' oil/coolant emuslion showing up once. And white coolant out the tailpipe is also uncommon for our cars. It can all happen, just that the most comm on is either external seeping/weeping/dripping happens, or full-blown combustion gasses in the coolant pushing it into the overflow tank (particularly 1st run of DOHC 2.5 liter engines in the late 90s to 2000 or so). stay in the habit of checking level in the radiator, confirm OEM style thermostat (a MUST) maybe get a new rad. cap. On both my cars, I clamped the overflow tube to it's nipple on the rad neck. I used 2 small zipties. confirm rad fan operation - they can fail or, confusingly, get intermittent - sometimes coming on when tapped.
- 13 replies
- 2001
- Subaru Legacy
(and 6 more)
Tagged with:
^^ what he said - lack of lube or too much rust or some other issue with the caliper sliding.
