105
as a VERY general rule, avoid late 90s to 2000 or so 2.5l DOHC engines. (severe HG failures if not rebuilt with MLS gaskets) I'd suggest used turbo engines are also very risky, the worst being around the 2007-8 years, depending on model. (oil screen problems) used cars of all type have issues. Also, even the above problems can be mitigated if caught soon or 'properly' rebuilt. plenty of other little gotchas here and there....what are you considering?
if the car were cranked with the hood up and someone listening to the noise - where would it come from? F B L or R, etc.?
- 3 replies
- 1999 subaru forester
- turbo
(and 2 more)
Tagged with:
disappointing I know, but it seems Subarus do go through wheel bearings faster than we'd like. I had a rear go out at less than 50K miles on my 06 WRX so..... no question its the bearings?
- 8 replies
- wheel bearing
- front wheel bearing assembly
(and 1 more)
Tagged with:
double check you are using the correct marks, line them up (there are pics on-line) and install. I like to also confirm things with a tooth count, before pulling the tensioner pin, after pulling it, after rotating the engine with a wrench - basically, trust the marks and the tooth count, but triple check everything. NEVER use the arrow/triangle mark on the front of the crank pulley - don't worry about a whiteline being off a half tooth on the back of a new belt. Don't worry about those lines after you rotate the crank with the wrench - it takes 2-300 revs for those lines to sync-up again. use the marks on the pulleys and a tooth count. when the mark on the back of the crank pulley is lined-up, one side of the engine has a piston halfway down from a power stroke and the other halfway up on compression. That cam's valves are closed. The other side (the left/US driver's) has it's pistons halfway down on intake and halfway up on exhaust - those various valves are open. you can find Subaru engine animations on line too.
I'm kinda concerned you may have more than one problem. a possible cause of the poor-running until after warm-up might be a bad engine temp sensor. in newer soobs it shares the same housing as the temp gauge sender - 3-wire unit. the FSM (or someone here) may know of a way to test it if you don't want to just swap it out. as alluded above - old wires can cause misfires, particulalry in moist/wet weather. heat dries the engine compartment and misfiring is reduced. As a tes, when it is idling smoothly after warm-up, pop the hood and spray the spark plug wires and the coil with a plant mister of tap water. If the engine stumbles, could be time for new wires/coil. Oil on the plug wire boots is another source of misfiring. plug tubes should be dry.
