105
change the air filter? check the tabs on the far end of the box. you can run the car briefly with the belts off. many people find air in the power steering after they've 'disturbed' the hose. look for bubbles/foam in the tank while idling.
- 4 replies
- alternator belt
- idler
(and 3 more)
Tagged with:
RockAuto.com Discount Code - Expires November 17th 2015
1 Lucky Texan replied to RockAuto's topic in Products for your Subaru
thanx! -
check the crank pulley for wobble. If the inegritiy of the rubber in the 2 piece crank pulley degrades enough, it can even sping, throw belts and other wise act up. Some folks say to use a permanent marker or grease pencil to draw a line across the pulley, then check that it's lined-up after a drive. The car can also be briefly run with the accessory belts off. If no squeak, then it could be an accessory's pulley????
Did a coupla small things to my WRX; used the Turtle Wax kit to clear the headlight lenses, - worked well, I'm happy with the results. I also had to use a Dorman product to tether my gas cap since the plastic stock tether broke. It wasn't a perfect solution, but cheaper that a new OEM unit. the wire is quite tight and didn't spin well. I used some pliers to 'recurve' the tips of the wire outwards a little to prevent dragging.
also, the 3K limit seems like 'limp' mode, but, no codes? could this car have had the ECU re-flashed? it's possible codes have been removed form the reportable list. I had to kill about 14 codes in my WRX relATED to my frozen-shut aircut valves. Intake runners (tumble generator valves) can stick and put the car into limp mode for instance - likely other stuff does as well. but, weird that there are no codes. just for S & G, try doing a code erase/ECU reset next time this happens. See if the car behaves better/differently.
