105
leaking at the rear of the engine on the legacy 'might' be the air/oil separator plate. I can never recall what years have the troublesome plastic plate. You said trans though - sure about it? I have no experience with Mobil 1 but it isn't popular with soob owners. You seem to have good luck with it. I'm in no position to criticize, I can tell you that I use Walmart synth 5w-30 in the winter here in DFW, and Shell Rotella T6 synth 5w-40 in the summer. 6 month schedule due to low miles. about 5-6K on our 03 Outback, about 3-4K on my WRX. I'm sure they'd go longer. You could try using Blackstone labs oil analysis to help stretch the changes out - maybe read-up a little over at bobistheoilguy.com
that's called a 'Tachometer' and shows engine rpm (revolutions per minute) https://en.wikipedia.org/wiki/Tachometer You seem to have a car with an automatic transmission. If so, you can pretty-much ignore the tachometer. Of course, if you notice odd behavior from it when you experience a problem with the car - you should mention it to your mechanic. Also, when the car's shifter is in Park or N (neutral) never press the accelerator such that the Tachomoter's needle stays in the red zone. A relative with more familiarity with cars might be able to give you some more tips about the entire gauge cluster (as well as other parts/systems in your car), and your owner's manual will have a little information too.
I guess there's some confusion. Do you have an AWD vehicle or a FWD Legacy. I think FWD went away about 1996? ebay has LSDs for the front diffs of Subarus from several hundred to $1500 or so. Not sure on application to your car's trans. Cusco, OBX, Quaife, maybe Giken... just need to email, research what fits that trans. here's a thread about the OBX - http://forums.nasioc.com/forums/showthread.php?t=700370&highlight=obx+diff
meh - many makers of tools/supplies used by mechanics make/made promo items featuring female models. You see much the same in auto, boating and other similar magazines popular with men. If there were a history of auto repair shops staffed by females, there'd be calendars and posters of shirtless ,buff young men holding babies. or Italian shoes.
you would be EXTREMELY lucky to suffer a timing belt failure without valve destruction in that 2.5. I changed my WRX's timing stuff at 8.5 years, mileage was way under the 105K. Glad I did too, the toothed idler was crunchy and a little wobbly. Another was very loose and slightly noisy. belt was fine. That idler would have puked it's bearings before 105K I feel certain. And, I will probably accelerate the next change to 6 years or so. (unless I start putting more miles on) because I didn't change the waterpump or cam/crank seals.
the door pulls on the front doors, particularly the driver's side, were getting severely wrinkled and the vinyl w'ever covering was splitting and getting pokey. I found some velcro drink 'cozys' that you wrap around a bottle or can on sale for $1 - , they aren't a good color match, but they hide the problem. - so far the wife considers them a good solution (whew!)
vacuum gauge testing is cheap/free and might help rule-out one or two problems. Symptoms kinda seem like car might be running lean. You could also try spraying some carb cleaner around vacuum lines and intake manifold when it is missing at idle - listen for it to smooth out if it sucks in some cleaner. fuel pressure maybe low?
no oil on the plug wire boots? was the timing belt system serviced at about 105K miles? One thing that kinda fits the symptoms would be a bad Engine temp Sensor keeping the car 'choked'. Some data from the ECU might help confirm that. There may also be an ohmmeter check in the FSM for that sensor - others may know what to look for.
well, a shop should have both experience and equipment for proper bearing replacement. There are hub 'tamers' and 'sharks' ,etc. - DIY tools. maybe even borrow similar tools from a parts store - but a shop will have a hydraulic press. If they can't get it out of a knuckle, you wouldn't have either and will need to get a knuckle, maybe from a junkyard? That ebay bearing is marked NTN and japan so, probably OEM. Fairtax should have a better idea of how much $/hassle it is for a first-time DIY job. I just suggested it as an 'intermediate' approach.
Rainy - ask for a shop recommendation in a new thread. Might be fortunate enough that another member here knows a good mechanic near your city. You may not need new rotors if they are fairly smooth and above the minimum thickness stamped on them. Often, that wobble feeling comes after a panic stop and holding the brakes clamped in one spot waiting for a light or train, Sometimes, lightly dragging the brakes with your left foot for 2-3 blocks - followed immediately by a mile cool-down run, will clear that uneven deposit off. machining rotors or replacing will do the same thing - for more $$$.
stick a wire/toothpick/w'ever in the hole, mark the depth, pull it out and compare to the bolt's length?
- 6 replies
- Belt
- 99 outback
(and 1 more)
Tagged with:
