105
well, a vacuum gauge might tell you something and is cheap to try (mybe free if you 'loan' it out from a parts store) Seems like there could be a wiring or grounding problem. Also, I THINK a couple of those sensors assoc. with those codes use a 5V reference signal from the ECU. If one sensor is killing that, it could affect the others that use it. maybe there's a common ground or a rodent-chewed wiring harness or loose connector? the noise could be a poorly seated airbox after a filter change.
I think some folks with older soobs have used a higher output alternator from Nissan Maximas ??? what symptoms do you have? You could have a local rebuilder rebuild you alternator, you'll spend a little and wait a coupla days but have a MUCH better unit than what you get from a parts store. Also, there is a special part number for Subaru rebuilt alternators and folks say they are good.
Just to be clear, if I can locate everything, i have used (less than 10-12K miles) Prothane bushings already in front LCA rear Outback housings, and unused Prothane inner bushings. They are harsh going over sharp transitions (like uneven concrete expansion joints for instance) The Febest rubber units have been fine since I installed them. Also, user grossgary here at USMB has used them many times with no issues.
I HAD poly and dumped them for Febest. Drastic improvement in harshness. how they would compare to fresh OEM, I dunno. you can read the entire 'saga' here; http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/48910-lower-control-arm-rear-bushing-transverse-link-replaced-prothane-03-outback.html I still have the new inner bushings (I THINK) and the slightly used rear bushings. Dunno how much shipping would be but, make me an offer. Unless you plan to lift your leggy, you won't need the actual mount so, shipping will be a little less if I pull the parts out of the mount. Some folks say the housing isn't different enough to matter. And you will want to source some new grease to put on them after you clean them up. a new kit though is not expensive. If you are gonna track the car or run it off-road - or if it was never on anything but the smoothest pavement, poly would be good. Tightens up the steering responses a little, makes 'takeoffs' and braking feel, uh - more 'immediate' I guess. hard to explain.
is it a 5 spd? They often have TB develop after warming up. when the car is hot, do you still have jerking/binding in tight circles on dry pavement? has the car ever had a trans or diff swap? You say the tires are fairly new, but, are they ALL 4 the SAME exact brand, size and model? has it been operated with mis-matched tires in the past?
tell us more about the car's history? is it a 5 spd? (they sometimes have torque bind that is worse after warming-up) tires all the same? ever have a trans or rear diff swap? u-joints and carrier bearing OK on drive shaft?
sorry, FreezeFrame. it's a limited amount of data some OBDII readers can get when reading codes. fuel trims and temperatures etc from some sensors at the time the CEL was set. My old Innova 3100 can read FreezeFrame data. not as good as live data from FreeSSM or maybe that torque app for smartphones. if you have a smartphone, check into an elm327 BT adapter and the Torque app.
