105
seems to me, there's no certainty about the HG leak - except for dealership info. If it had no symptoms of HG leaking before the fuel pump issue (which you MAY have been able to fix for ~$75) why did these symptoms show up at the dealership? I think you might consider getting another opinion. But, if you've made-up your mind, consider measuring the valve clearances and be prepared to adjust any out of spec - not a trivial job. if there is misfiring, that could easily lead to a fuel smell - unburnt fuel. the CEL on? post any codes. If coolant isn't being pushed into the overflow, if no streams of bubbles are seen in the radiator while running - I'd be tempted to think the shop is fishing for some of your $$$.
- 12 replies
- H6
- head gasket
(and 2 more)
Tagged with:
on the 2014, do any of the airbags exit from a seat back? Seat covers might interfere with that. just wondering.
- 8 replies
- Seat belts
- legacy
(and 2 more)
Tagged with:
swap the tires front to back first. probably not an issue but - easy to try. And sounds like you feel certain there's no binding of caliper movement.(some people remove the rubber bushing on the slider pin) do a bedding-in procedure. a moderate one first. If no change at all (better OR worse) do an aggressive bed-in . If the problem gets worse after any bed in, you may have a part of a rotor with altered alloy characteristics (cementite ?) and you will need a new rotor. there are different ways to do bedding in, just make CERTAIN you do it in an area where it will be safe (from other people and police) to accelerate and slow down aggressively - followed by a cool-down run. You MUST NOT stop and hold the pads against a hot rotor. might be worth inspecting the brake caliper bracket and bolts - in the remote chance something is cracked.
is there another relay there with the same part number? swap them if so. see if the fans work better. some people have had intermittent fans.
you could take some temp measurements with a remote infrared thermometer. Also, lift the rear of the car and try rocking the tire up-down. (12 to 6 O'clock) comapre both sides. really should be zero movement. i gad a bad rear bearing that moved about 2mm, other side was rock solid. you can also compare sound with a mechanics stethoscope from side to side - might hear rough bearings.
most of us do fine with non-performance parts and normal driving without a bed-in. Is it a good idea? probably - might help if you engage in 'spirited driving' right out of the gate - but plenty of people would have no problems after the first 2-3 gentle stops. You could do a 30-30-30 . Do a normal stop from 30mph, Drive for 30 seconds, stop again. Dot that 30 times. But really, modern pads work well against decent rotors without much chance fro drama. make sure to clean any protective grease off the rotors. good opportunity to wire-brush off the front of the hub and I like to hit the studs with some gentle wire-brushing - just to knock off any corrosion. maybe put some light grease or something on the front of the hub to help keep corrosion down? some silicone spray or ???
those connectors activate all the evap solenoids so, probably not an issue. You'd have multiple relays clicking and fans 'cycling' on/off. but, there may be a common ground somewhere affecting the speedo. and the Temp Sensor, or fan relay ? With the age and all the work done, worth inspecting grounds and cable harnesses. GG will have more experience with the specific locations of things. If the fans are on when they shouldn't be and pulling (or tapping) the relay stops them - well, seems like a bad relay. If there are 2 or more identical relays, swap positions to confirm?
does seem like it could be the ECU is getting a bad signal from the Engine Temp Sensor. Getting data from it might help with this but, might be a cheap enough part to just throw one on. Even if you're wrong, it eliminates one thing, and you replace a 17 year-old part. you don't have any other relays clicking or odd electronic behavior do you? sometimes people mistakenly connect the green test connectors under the dash and their fans go crazy.
not sure what displays remain in that model but, there's very little current required to keep an LCD display up. Be VERY careful around a car battery, it's 'only' 12 volts, but there is a HUGE amount of energy stored in them and sparks/fires/explosions are possible. you may need help from a pro, but here's a coupla videos I found, you can find others or perhaps do a search here for some threads about it.
you can use a meter to measure the 'parasitic current' . If it is high, you can pull fuses for various circuits to help find the problem. But, if there was a poor connection to the battery, it may not have been receiving a charge. also, it should be mentioned, the more often a battery has been flat, the shorter its lifespan so, watch for that in the future.
doesn't the 05 Forry have an 'intermediate' design pump? Like, it has that long-ish cap with a strainer inside? I suppose it's possible it could have a ruptured o-ring and/or cracked cap just like the 2nd gen Leg/Outbacks get sometimes. That said, the wife and I both heard gurgling once in our 03 Outback. I think it is possible for it to be 'normal' but not 'common'.
hmmm....I'm gonna throw out Engine Temp Sesnor or its wiring/connection. maybe the ECU sometimes thinks the engine is cold and is boosting fuel ('choke' mode) Might not hurt to throw a vacuum gauge on there. Some parts stores will loan them out. If they don't have a chart of symptoms, you can find that info online easily.
No, I don't think enough people have been in a position to do it and actually track the results. It's worth pointing out though that probably 1/2 of the axles from junkyards and rebuilts axles get put on cars going the 'other' direction just by chance. In theory, the less-used reverse surfaces on the cages and cups would become the surfaces getting force going forwards. But, the balls/wheels themselves are still at whatever level of wear they have received over the years. I read of it, and would definitely do it myself - but "common' practice seems to be to put crappy rebuilt axles on.
