105
hopefully, all the tires are the same brand/model/size. Do some tight circles on dry pavement to see if you feel torque bind. generally, the older a car is, the more important its past care and current condition than its brand or model. The more owners it's had, the more chance something was abused. You might look at the 'sticky' threads here; https://www.subaruoutback.org/forums/gen-2-2000-2004.110/
92' Loyale Wagon Stuck in 4WD
1 Lucky Texan replied to J41YD3D.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
broken axle? -
triple check battery clamps? the car will run for a little while with the alt belt removed. Might help with some diagnosis. corroded bake light connector (remove bulb, look inside socket), bad 1157 type dual filament bulb(drooping/shorted filament), or bad wiriing in the 'gaiter; from body to hatch may play into this.
fork does not appear to be cracked.,,,, Some folks report problems with clashing/shifting if they use full synthetic GL-5 in the trans.(synchros are spinning at the wrong speed???) If that's what you used, try non-synth lube. Or, some folks say the walmart Supertech synth-blend is good value and works. hopefully, you'll get better ideas from others.
if MT, during a test drive , AFTER the car is warmed-up, do some tight circles on a dry , paved parking lot. The car should move smoothly. (this assumes you've already checked for all tires to be identical. brand/Model/size.) timing belt system service is every 105k miles OR 105 months, w'ever come first.
could be a good application for those Irwin extraction tools. Or do as suggested above, but use a left-hand drill(s) - sometimes the warmth and vibration will spin the plug out leaving the threads in the block OK.
