1 Lucky Texan
    105
  1. tricky sometimes downsizing rims due to brake caliper clearance. Discount Tire or TireRack should list anything in 15 that will work.
  2. the little 'orifices' are usually adjustable. Sometimes a sewing needle is all that's necessay. Some designs may need something special, probably available foe a couplabucks at the parts store.
  3. Oh, very important to know the state of the timing belt system.(interference engine) How long since last serviced, and were Japanese or OEM parts used. the 3 things most likely to send an older soob to the scrap yard; bent valves, overheating/head gasket failure, or major transmission issue.
  4. hopefully, all the tires are the same brand/model/size. Do some tight circles on dry pavement to see if you feel torque bind. generally, the older a car is, the more important its past care and current condition than its brand or model. The more owners it's had, the more chance something was abused. You might look at the 'sticky' threads here; https://www.subaruoutback.org/forums/gen-2-2000-2004.110/
  5. is the car new to him? any chance the tires are mismatched or a prev. owner has swapped trans or rear diff to non-matching final drive? I wouldn't rule out trans fluid bad/contaminated so, I agree with that as step one. I THINK you can use the European Valvoline MaxLife fluid.
  6. if the car sat unused for any length of time, rodent damaged wiring could be a possibility.
  7. maybe some issue with engine temp sensor or its wiring? opening/shorting with temp or something....?
  8. triple check battery clamps? the car will run for a little while with the alt belt removed. Might help with some diagnosis. corroded bake light connector (remove bulb, look inside socket), bad 1157 type dual filament bulb(drooping/shorted filament), or bad wiriing in the 'gaiter; from body to hatch may play into this.
  9. fork does not appear to be cracked.,,,, Some folks report problems with clashing/shifting if they use full synthetic GL-5 in the trans.(synchros are spinning at the wrong speed???) If that's what you used, try non-synth lube. Or, some folks say the walmart Supertech synth-blend is good value and works. hopefully, you'll get better ideas from others.
  10. if MT, during a test drive , AFTER the car is warmed-up, do some tight circles on a dry , paved parking lot. The car should move smoothly. (this assumes you've already checked for all tires to be identical. brand/Model/size.) timing belt system service is every 105k miles OR 105 months, w'ever come first.
  11. how long has it sat? what mileage is on the car? why was it parked? AT or MT?
  12. well, several things come to mind but, yeah, I'd have everything inspected closely. maybe a rim is bent, or another stud has cracked or improper lug nuts used or nuts are not properly torqued, etc.
  13. please name dealership. Yeah, I've worked in manufacturing mostly and we made mistakes, occasionally a 'doozy' but, it's how you handle it that matters.
  14. could be a good application for those Irwin extraction tools. Or do as suggested above, but use a left-hand drill(s) - sometimes the warmth and vibration will spin the plug out leaving the threads in the block OK.
