105
^^^ triple check final drive of trans and rear diff. older 4eat clutchplates have a drive drum that gets 'grooves' i think, can cause clutch plates to hang-up. maybe just got unlucky with the trans swap? might just try another trans or, swap just the tailshaft part - if someone can confirm it will fit, try to get a 98 tailshaft or newer - coupla improvements after 97 1/2 from what i read.
good point here! If you do not hear anything - could be an inhibitor/neutral safety-type problem. Try starting in neutral or shifting in/out/in/out/in from park and neutral. 'pop' the brake pedal with 2-3 quick taps when stepping on it. if 5 spd, 'pop' the clutch pedal. at least, i think a 2000 will have the system in place that checks the pedals? anyone?
You really need to pin-down where the problem is. maybe get a soob-experienced mechanic to test drive it? http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/27878-4eat-tail-section-rebuild-without-removing-transmission.html the solenoid and clutches are in trans fluid. The drive part can become grooved and the clutches can bind-up. Also, i have read that after about n97 1/2 , the valve was changed. maybe a tailshaft from a 98 or newer in the junkyard would fix your car?
u-joint, carrier bearing also possible culprits. when you read of binding being worse when warm, those are usually the 5 spd transmissions. Cneter diff in them is a lot different than the wet clutch pack in the auto - and they have no FWD fuse. But, pretty sure a 94 has the 'bad' aluminum sleeve problem that cause the clutch plates to bind. and, I'm not certain how it might behave with temp. Could need a tail-shaft rebuild or, maybe someone knows if a newer style trans will swap in?
