105
some additional info - much of this is arguable, just what I take from what I've read; modern turbo cars do not have unusually high HG problems like the late 90s 2.5 NA engines. the late 90s 2.5 that do exhibit HG problems, IF properly rebuilt with mls-type gaskets, are 'likely' as reliable as any other used engine. WRXes are cheap-ish sporty cars, be VERY careful buying used as 'kids' have probably reamed-out many of them. At least pay to have the pipe dropped and the turbo inspected for shaft play. learn about the banjo bolt oil screen problem on some turbo cars 'most' people would say the cars ARE very easy DIY vehicles. other than sparkplugs on H6es and some parts under turbo piping, access is good to excellent. tuning the ECU and go-fast bits are both easier to find for the turbo cars. the Forester is a frequently overlooked platform and would make a great 'sleeper'.
supercharging the H6 has been done - see user cardoc postings at subaruoutback.org (but I think boost was only about 1/3 the turbo imprezas) but really, unless you want a HUGE project, just get an STI or WRX to begin with. I LOVE my 06 WRX Wagon. what kind of motorsports are you interested in? if you want an eighth or quater-miler, Subaru is not a great choice - start with a Mustang or similar. but, if you are interested in a road course, or autoX or rallyX, get a WRX or STI. 3142plateless by alckytxn, on Flickr
you can make the car more fun to throw around the corner. And reducing mass will give it a little more pep. lighter rims, maybe a lightweight crank pulley. If 5spd, a lighter flywheel. Never haul around tools or heavy gear. If you will always be near home - consider leaving the spare and jack where a friend could bring them to you. If you literally never have passengers, remove the seats. suspension and brake upgrades are common - try a search here, at subaruoutback.org and maybe NASIOC boxer4racing.com and others have bits to help with suspension and similar mods.
Our 03 has it next to the battery like that. It has the weather [ackage but I'm not certain about towing package. We have no hitch. I wouldn't change it unless the case got opened or maybe someone used an incorrect fluid or similar major issue. supposedly, that filter (which is very different from an oil filter BTW) was added by JATCO or whoever to clean-out any debris after original assembly.
2.5 liter? 105K miles OR 105 MONTHS, whichever comes first. belts are tough - an idler will seize or dump its bearings before the belt breaks. then you have bent valves. get the TB area serviced soon, new idlers, tensioner probably waterpump and maybe cam/crank seals. Consider having the oil pump backing plate resealed.
many items of an upgraded suspension will add NVH. The endlinks have bushings so, not really a big deal. You could just run what you have until one breaks, then get some kartboy or Whiteline w'ever endlinks. My kartboy links made no difference I could detect in noise. But I had some prothane rear transverse link bushings on the wife's Outback and they were VERY noisy - got them changed out for Febest rubber units now. So, it kinda depends on where and what is being swapped out. just wondering if they were in with the swaybar deal or not. something to keep an eye on too.
I have some pics with rough measurements of free length and top and bottom diameter measurements of my 06 WRX WAGON OEM springs if that would help. pm me with an e-addy that can receive large-ish pics (2.5M each) otherwise I cannot answer the question. maybe that suspension thread at NASIOC has some guidance.
it's your call - if you have fairly low miles on a trans that is known to you and hasn't been neglected - changing the center diff is probably a good choice. but a high-mileage trans....well, you might consider a lower miles unit from a wreck and swap it in. Maybe someone will reply who has been in your situation.
I think 60K is a lot of miles on stock struts. They probably have 'some' life left. May depend on what type of miles though. I had a rear strut leaking on our Outback at about 63K miles (well, that was about when it was discovered....) I change all 4 struts and, while perhaps not 'worn out' the other 3 were noticeably weak compared to the new struts. But, her car gets 95% side street use. Highway miles are different, I'd think dirt/gravel would be the worst. just a single observation.
are all 4 tires the same brand/model/size ? Likely center diff - particularly if this is a manual transmission. HOWEVER - torque bind is almost always felt as a jerkiness or 'holding back' when turning in tight circles. What you describe, if it's noise only, could be something else. A bad front CV joint or possibly a bad driveshaft component (u-joint or carrier bearing.) Try to make arrangements with a good mechanic familiar with Subarus and demonstrate the problem for him.
