105
there can be multiple issues. The rims may be an improper offset and a tire(s) could be rubbing. Also, stress could be put on the wheel bearings. There could be -uh- centralizing? , problems if the center hole is not correct for the hub. the main problem is rolling radius. If one or more tires are a different ACTUAL size, it can cause torque bind. bottom line, you are right to be concerned about this and it needs to be investigated/corrected soon. check ebay and maybe craigslist for rims. Try to confirm rims are hub centric for Soobs and have the proper offset. Make sure tires are the same brand/model/size and close to each other in wear.
if the steeering feels OK, I'd just look in the reservoir for bubbles/foam while idling. If none, I'd pursue the noise issue further or run the car without the PS belt. to see if the pump is causing the noise. If not, run the pump til it becomes a real issue. (if you do see bubbles, just start with o-rings, hose clamps w'ever)
When I did my WRX , the toothed idler was rough-feeling and slightly wobbly - spun like skate wheel. One other idler also was very loose as well. Belt looked great. belts seem to be tough, but when a roller pukes its bearings, that can cause issues for some of us. At least a 2.2 won't lunch its valves if the timing slips.
hard to say about the sound. On my laptop, best guess would be a bearing. perhaps accesory belt tensioner ? If you could be allowed to briefly run the car with the belts removed, that might help pin-down the noise source. also, PS systems on Soobs frequently suck air in thru bad o-rings or hose connections (even cracked fluid tanks) from the suction side of the reservoir. this can cause enough foaming/bubbles to push a little fluid out the reservoir. But fluid at the pump itself could be something more serious.
loose/broken ground(s) wire could make that electrical interference. also, see if it comes/goes with turning the defroster off/on for the hatch. Some of our cars can pick-up noise from a broken heating element/trace clunk thunk? not sure, motor or trans mount could have been damaged with the work - dunno why that would be temp dependent. I've read of many people using hose clamps on heat shields.
Denso would be preferred. Could there be rodent-chewed or otherwise damaged wiring from that area of the car?
- 12 replies
- oxygen sensor
- o2
(and 7 more)
Tagged with:
if one of those techniques works 2-3 more times, I'd say you have a place to start troubleshooting. does your CD player work? there have been stuck CDs in the past causing parasitic drain. Also, if you can use an ammeter, start pulling fuses. You might see a major drop when the guilty circuit loses its fuse.
people have accidentally hit the parking switch on top of the steering column (virgin switch) on many occasions. Might be easy to overlook too. any way, sounds like checking for parasitic drain would be a good idea. consider also, a battery that has had multiple complete drain events will have limited life span.
