105
based on the description, it does seem like a CV joint. Even more likely if a rubber boot (at either end) is torn. Also, if one of them is an aftermarket/rebuilt - they may have a reduced lifespan compared to OEM. But, tell us if this is a 'jerkiness' felt in the car or just a sound? also, to be clear, this isn't something you hear/feel WHILE rotating the steering wheel - but something you hear during the car's turn right?
not sure but what I see as fuel trims are mostly OK. single digits on an old car are not that bad. Being negative 'could' mean that there's a little misfiring /poor burning occasionally and the ECU is pulling back some fuel. (negative numbers are lean, pos. numbers are rich) if you recently disconnected the battery, that may be why you're showing OL. So, the numbers you have may not be very diagnostic as the ECU is using a fixed map. advance seems weird, like a bad knock sensor? MAF and MAP ? dunno what's up with those, maybe someone else will have some insight.
there can be multiple issues. The rims may be an improper offset and a tire(s) could be rubbing. Also, stress could be put on the wheel bearings. There could be -uh- centralizing? , problems if the center hole is not correct for the hub. the main problem is rolling radius. If one or more tires are a different ACTUAL size, it can cause torque bind. bottom line, you are right to be concerned about this and it needs to be investigated/corrected soon. check ebay and maybe craigslist for rims. Try to confirm rims are hub centric for Soobs and have the proper offset. Make sure tires are the same brand/model/size and close to each other in wear.
if the steeering feels OK, I'd just look in the reservoir for bubbles/foam while idling. If none, I'd pursue the noise issue further or run the car without the PS belt. to see if the pump is causing the noise. If not, run the pump til it becomes a real issue. (if you do see bubbles, just start with o-rings, hose clamps w'ever)
When I did my WRX , the toothed idler was rough-feeling and slightly wobbly - spun like skate wheel. One other idler also was very loose as well. Belt looked great. belts seem to be tough, but when a roller pukes its bearings, that can cause issues for some of us. At least a 2.2 won't lunch its valves if the timing slips.
hard to say about the sound. On my laptop, best guess would be a bearing. perhaps accesory belt tensioner ? If you could be allowed to briefly run the car with the belts removed, that might help pin-down the noise source. also, PS systems on Soobs frequently suck air in thru bad o-rings or hose connections (even cracked fluid tanks) from the suction side of the reservoir. this can cause enough foaming/bubbles to push a little fluid out the reservoir. But fluid at the pump itself could be something more serious.
loose/broken ground(s) wire could make that electrical interference. also, see if it comes/goes with turning the defroster off/on for the hatch. Some of our cars can pick-up noise from a broken heating element/trace clunk thunk? not sure, motor or trans mount could have been damaged with the work - dunno why that would be temp dependent. I've read of many people using hose clamps on heat shields.
Denso would be preferred. Could there be rodent-chewed or otherwise damaged wiring from that area of the car?
- 12 replies
- oxygen sensor
- o2
(and 7 more)
Tagged with:
