105
if one of those techniques works 2-3 more times, I'd say you have a place to start troubleshooting. does your CD player work? there have been stuck CDs in the past causing parasitic drain. Also, if you can use an ammeter, start pulling fuses. You might see a major drop when the guilty circuit loses its fuse.
people have accidentally hit the parking switch on top of the steering column (virgin switch) on many occasions. Might be easy to overlook too. any way, sounds like checking for parasitic drain would be a good idea. consider also, a battery that has had multiple complete drain events will have limited life span.
well, if there is a click, but no cranking, I'd definitely consider new plunger/contacts in the solenoid (on the starter) as an experiment, sometime when the contacts are intermittent, a car will start after you whack the starter. Use a piece of 2x4. Try a tap first, then a 'bunt' then, a 'single'. if you literally hear nothing, could be some kinda ignition or neutral safety switch. Though jumping 'shouldn't' help with those failures.
well, I have a set of stock springs off my 06 WRX wagon, less than 1800 miles of use. You pay shipping plus $25 and you can see if they will work for you. I could take some free-length measurements but, i also don't know if you can use them. There's an entire thread at NASIOC about what suspension will work on other cars.
ask the parts store what they loan out. You'd be surprised. I borrowed a vacuum pump to recharge my a/c . You have to 'buy' the item, but they credit your card back when you return it. probably can borrow a vacuum gauge. Might need to buy a plastic T and some hose though. might help determine a sticking valve or clogged exhaust.
A vacuum gauge is very inexpensive and there are guides online to help with interpreting the readings. You may be able to borrow one from a parts store. Posting live or freezeframe data here will get you some good analysis but, I suspect finding a good local shop is gonna be more likely to pay off for you in the long run.
auto trans fluid is the only one that requires you to check while idling to get an accurate reading. Even better if the car is at operating temp. (the fans have come on at least once) many people overlook that. i even know better, but gave myself a fright years ago when hurriedly checking fluids before a road trip - thought the trans was overfilled for about 10 seconds! lol! trans-x, even new fluid, may take a while to help with any gummy deposits or stiff seals, etc. Of course, if the car isn't getting better - time to look elsewhere. Additives cannot fix most true failures. The can 'occasionally' undo poor maintenance, in certain areas, IF you are lucky.
nipper, does it seem the rpm go from normal to higher than they should or lower? that is, is the ECU boosting for a load that isn't there (compressor clutch is slipping or ???) OR, are RPMs dropping because the compressor clutch engages but the ECU isn't boosting the RPMs? 05 isn't DBW so, is there a solenoid somewhere that boosts rpms? (man I'm ignorant of this part of a car's system!)
never read of that issue before. others here will be better able to advise you - just make sure you need an engine before proceeding. If the issue is 'only' in the heads (no overheating, oil starvation, etc. that would affect the other internals) - you could get used/rebuilt heads put on, with MLS gaskets, and perhaps have a more reliable engine than an entire used engine.
wow, low miles, well, you may still be a coupla years away from a TB service. (original battery? I have had a bad battery trigger spurious codes) We would need more details to even offer educated guesses at this point. Codes would be helpful. i think there is a way to get the car to display the codes on the dash. then, you should be able to reset the ECU; disconnect neg. cable from battery, step on the brake pedal, wait maybe 15 minutes, reconnect(or,disconnect the batt. neg. cable overnight ) reconn. and see if the car runs normally, pops the CEL with new codes or gos back into limp mode?
