105
well, old sparkplug cables can become brittle/compromised in such a way that, most particularly in 'moist' weather conditions, they cause misfires. Seems unlikely to cause an actual stall, but, misting the idling car's engine with a plant sprayer, at night, will sometimes cause rough running and you will see arcs from the high voltage bypassing thru the insulation. so, any correlation with your symptoms and wet weather? Is the problem MORE or LESS likely as the car warms up/dries out? a poor/intermittent ground connection or harness could cause your problem. You could try gently pulling/pushing on cables while the car is idling.
I chock the front wheels, pull the parking brake to the first click, lift the rear at the diff and use stands at the flat-jacking pinchwelds. Then, pull the little rubbder plugs out of the backing plates. Use a flat blade screwdriver and rotate the star wheel UP until the wheel won't turn. Put the plug back in. repeat for the other side. that should do it. It is possible the little shoes are worn out I guess. You can buy a rebuild kit. i have never adjusted the inside so, dunno how much wear on the shoes can be created by that adjustment.
when was the timing belt system serviced last on that car? You will bend valves if it fails. And it's rarely the belt that fails, an idler will seize or puke it's bearings. if you suspect the car was neglected, or even just has normal build-up with age, nothing wrong with a throttle-body and maybe IACV cleaning, and a SeaFoam vacuum line or spray-nozzle treatment. many people like Marvel Mystery Oil treatments too, mostly for hydraulic lifters I guess. Techron seems to actually work. not sure it's better than SeaFoam in the tank though... Subaru Coolant Conditioner can help slow/stop/prevent small coolant leaks - ONLY install per bottle directions - ONE bottle max. (if you drain and re-fill the cooling system and swap any parts, ONLY use an OEM style thermostat - there IS a difference)
is the check engine light on? automatic transmission? KYB struts are the most commonly preferred. you can find DIY help here and elsewhere online for that.
yeah, likely to spew codes if a ground were really bad. But, some codes stay 'pending' unless they occur 2 or more times within X drive cycles w'ever. might be nice to see what the fuel trims are if you can get frezeframe or live data. Some smartphones apps can do that with a $20 elm327 BT adapter i think. My old Innova scanner can get FF data. related to other posts - if the car runs better in open-loop or immediately after a hard reset, there's likely bad data from an A:F sensor. or related sensor. O2, MAF, Knock, maybe engine temp, etc.
in a turn, force is vectored to the outside of the turn so, maybe start there as you say. After a run on the highway, compare the temperature of the rear hubs - side-to-side. The hotter one may have a bad wheel bearing or some craziness with the brakes. def check the lugs/studs too. You could lift the 2 rear corners and try to lift/rock the wheel up/down in a 12 o'clock to 6 o'clock manner. Shouldn't be any motion. (again, compare side-to-side). I found a bad wheel bearing that way, the tire rocked about 2mm. Some folks say you can rest a hand on the spring and rotate the wheel - feeling for roughness/vibration.
