				Posts10142
				Days Won105
	the car is in limp mode. If the car has been well maintained and oil level/quality is good and there have been no wrecks/recent repairs (have there?) , I would start by clearing the code. A code reader can do this - or, disconnecting the neg. battery terminal, stepping on the brake pedal a coupla times, and maybe also waiting 10-20 minutes (or, disconn. neg. batt. terminal at bedtime, re-conn. in the morning) then, see if the code comes back immediately. If it does, probably needs the attention of a mechanic that could properly diagnose it according to the factory service manual.
	OBD I isn't likely to work with a handheld - not sure about a laptop with a cable and FreeSSM. THose should be able to use the 'blink code' method if you connect some connectors under the dash. I think you can make an '07 car display the code - I can never recall the procedure. You could also try clearing the code with a battery disconnect. any decent reader should read it - or go to PepBoys, O'Reilly's , etc.
	from what I've read, many times actually, first thing to suspect would be a rebuilt alternator. If that's what you installed. If possible, take it and the battery back to the parts store and have them tested. If they still have your original (and assuming you can be wwithout your car for a few days) you can have your original alt. rebuilt by a local rebuilder - ask around at a 2-3 mechanics' shops and see who they'd recommend.
	speaking very generally - yes. It is true the EZ30 is not reported to have hg problems as often, they also are less common so, the actual difference in RATE of hg problems is not easy to quantify. But the impression is, the 6 cyl gaskets are more robust. BUT, the older a car is, the less important it's brand/model reliability when new - and the more important is previous care and current condition. A properly regasketed EJ25D could be more reliable than a mistreated EZ30. ANY 14 year old car could be a ticking time bomb.
	unless you were running a donut spare or different sized tire, it's not reported as a 'come$go' type of issue - the 5pseeds are often reported as being worse after they heat up. symptoms get worse over time. It stresses the entire drivetrain of course and worn-out/broken parts elsewhere could exhibit problems - wherever the weakest link is - carrier bearing, u-joint, half-axle/CVJs, etc. if it seemed like it was worse on one side than the other, might be useful to swap axles L to R. just, really, doesn't seem like TB. I'd think you would FEEL the stress buid-up/release/build-up/release, etc. is the banging started or solved by brake application? Have you tried lifting the E-brake handle to see if the sound is affected? are the pads on the rear brakes evenly worn? inside pad material not worn a lot more than the out side pad? I only read a lot, others here have the real experience.
	that's why I asked about the feeling. One test for torque bind would be tight circles on level dry pavement. If you can't idle thru them or , maybe , get trhu them at 1K rpm without feeling some bucking/jerking - you may have an issue withthe AWD system. have you tried swapping wheels front-to back? Inspected the swaybar endlinks? Check the lug nuts/studs, check the axle nut, etc.
