105
I'd be tempted to clear those and see what comes back. if voltage is actually wonky - that can cause 'spurious' codes to set. so, thoroughly check the battery and charging circuit. also, I'd imagine it would be easy to miss some ground connections with an engine swap so - google up some images and try to locate all the grounds and confirm they are good.
there are sensors at each wheel and a pump so, there very well could be other issues with the ABS. Since the car is new to you - it's worth checking the charging system too as low voltage will often show up in the ABS system first. Is the check engine light on? getting the codes and posting them here is often helpful. was that engine rebuilt with multilayer steel headgaskets? more details about the car/engine/swap and specifics about how it's running/driving poorly will help. There are guys here with tons more experience than me , I just read a lot, so, they can probably guide you better.
that car likely has a MAP mushy brakes are most frequently from air in the lines so, strat with a good flush/bleed. many people complain of soobs having a spongy feeling when actually, the pedal travel is just a tad longer than other cars. But, if you still have a problem after a bleed, start by looking for stuck calipers or cracked caliper brackets or associated bolts. Then, if that's all good, it may be time to investigate new rubber or stainless steel lines at the wheels or a master cylinder brace.
PS system may be pulling in air - several threads about that. The car can be run minus the TB covers, might be worth checking foe excessive belt movement and looking at the inside surface of the covers for a place the belt is hitting. Also, the 2 piece crank pulley might be separated from its rubber. Look for excessive wobbling/run-out and maybe use a Sharpie or some paint to mark a line across its front - run car, see if the line separates.
I would only use Gates or Mitsuboshi belts. If you replace the waterpump - I've read you should use a Subaru METAL gasket and a Subaru or Aisin pump. All but one of the GMB rollers I put in my WRX seemed as good as the original rollers. Of course, I dunno how long they will last. Nothing wrong with doing the next belt change at 80K or 90K instead of 105K if you're worried about the parts quality. Of course, you could also get OEM parts, but they are pricey.
you might try boxer4racing.com , they used to keep some legacy bits in stock. kartboy, mishimoto, perrin, cusco, etc. may have some stuff ebay might get you some clear corners - not sure. There are youtube videos and othe r info around to bake your headlights apart to paint or install HID projectors.(the retrofitsource.com ,etc.) custom rims would help, you could pull, sandblast, paint your calipers, some stuff made for Imprezas might be adapted to your car. some of the guys here and over at subaruoutback.org and elsewhere may post stuff they find at junkyards in the classifieds. You can also post WTB in the Forums' classifieds - some folks may have some stuff laying around....
first item sounds like aftermarket axles - search,- well known problem. I suppose it's possible a worn original axle 'could' do it too.
- 3 replies
- baja
- transmission
(and 2 more)
Tagged with:
some plastic covers would need to be removed to view the toothed timing belt and to check proper timing of the crank and cam pulleys. you may need a mechanic if this is outside your abilities. Sometimes, an old trick of holding a strip of paper at the tailpipe while cranking, to observe if it seems to be sucked inside at some point, MIGHT help point to slipped timing belt problems.
