105
people seem to use 2 different numbers but, I used a Viton (I think 75 durometer?) 928 metric o-ring. I lubed it with a film of engine oil. One of the tabs has a dimple meant, I think, to be a stop so, don't turn the cap too far, it might put pressure on that tab if the dimple rides over the lug. if you didn't want to pull the pump again, maybe a fuel pressure test would work.
not sure what your goals are are, but, consider lighter-weight rims. it's a win-win because; you get to 'personalize' the car with rims YOU choose, AND, having lighter rims means less rotating, unsprung mass, so, it frees up a little horsepower. finding the weight of the present rims might be a little trick but, probably some guys over at NASIOC know.
I'm sure you're checking fluid levels while idling right? did you or previous owner have the front apart? from what I've read, it's easy to crack the pump pulling the parts together in that last 1/4" gap or so. other than those comments, I have no business being in this thread lol! hope you get it sorted-out.
I'd take 10 and and maybe a 12mm box end/open end for the battery - and probably a small adjustable end-wrench in case the terminal had ever been replaced with after market. It helps that the adjustable wrench has a little beef to it, you may need to tap the terminal sideways bac&forth to loosen it. maybe take a wire brush or some coarse sand paper to clean terminals?
is there a tooth count for this engine? I had a situation with a different engine where everything, including toohcounts, was dead-on, but the LS cam was just a little 'tight'. like, almost exactly 1/2 tooth. Any change I could have made would have altered the toothcount AND missed the marks on the belt. I called it good enough.
don't just replace the cat conv because the words happen to be in a DTC's description. Codes do not often point precisely to a bad part, just a system that is outside allowed thresholds. get the actual codes read at a parts store and post them here. Even better, if the parts store scanner can get freezeframe data (fuel trims ,etc.) post that info too. normal for a check engine light to be accompanied by other systems the ECU disables like cruise, and traction control, etc.
the other smell, if not sweet-ish/toasted marshmallows , could be grease from a torn inner cv joint on the exhaust. also, I think your car could have a cabin filter, if they get wet with condensation they can stink. Washer fluid can also stink.
OK, got it. sorry but, we get people across the entire range of mechanical ability. Kinda wondering if disconnecting the battery for while and forcing a reset could help. any signs the car has had the engine or trans out? It's easy to crack the trans oil pump marrying them back together. I THINK throttle position sensor problems can cause weird shifting problems but, I'm at the limit of my ability to help further I think.
others here have vastly more practical experience than me, I just read what they say. But, if you really are tackling the HGs again, do search and ask here about it. There's some good ways to DIY the heads' surfaces, might be some suggestions for a higher quality gaskets, etc. I think you have an SOHC engine so, probably can't use the turbo gaskets - but I'm not sure. Subaru does want people to use another bottle after any drain/fill. Pretty sure there's an RS specific forum too - those guys might be helpful.
