105
if you can't get to a mechanic soon to have the leak found and hoses/parts replaced, you could use a bottle of Subaru Coolant Conditioner, it may slow down or stop a small leak. (not recommended in the system has already had some leak stop installed, that ism do NOT double dose the cooling system with leak stop!) Mechanic will probably pressure test and change the hose. Small possibility there is a different type of leak involving a crack or pinhole in a more expensive part.
that Hopkins funnel with the tube on it works quite well for the front diff and auto trans. The transfer pump works for the rear diff. well, did for my cars. I may cut 2-3 inches off the funnel's tubing so it can support itself better, but really, it works fine as is. The black plastic adapter on the bottom fits well inside the dipstick tubes - just pour diff oil VERY slowly and it works. Before switching to fill with a different fluid, I use some of the old fluid I drained to flush the funnel/tube with. That way, I don't get any trans fluid in the diff or vice-versa .
Intake will get you more noise. Cheapest loud exhaust would be a 'turn down tip' . Unlikely those will boost power. not much you can do except shed weight. Lighter rims, lightweight crank pulley, lightweight flywheel if 5 spd . If you literally will NEVER have passengers, take the seats out, or just the rear seat. If you will ALWAYS be able to call someone local for help - leave the spare and jack/tools at home, etc. Rule of thumb, 9-13 pounds = 1 hp. There are mods you can do to make the car easier to throw around the corners, but non-turbo soobs don't have a lot of options for more power.
I'm not sure on a 2009 if Subaru's ATF-HP trans fluid w'ever is 'required'. It's good stuff, just may be pricey and inconvenient to acquire. (One trick to try, get pricing on any OEM parts/fluids from an on-line dealer like Fred Beans or genuinesubaruparts - others, and ask your local dealer to match prices, has worked for me and others on occasion) There may be a Castrol or other fluid that would be a reasonable fluid to use. Coolant may also be a point of contention - some people do just fine with a fluid like peak Global, others say you must use the Subaru coolant. There are 2 kinds so, check the manual. diffs, any name brand GL-5 is fine (synthetic or dino), check the manual, some cars actually spec different viscosities F vs R. I used a gear oil pump for the rear and a funnel with a hose on it for the front fluid fills. power steering also uses Dexron III or 6 w'ever fluid. Not some generic PS fluid off the shelf. I have used many brands and they all seem OK in my limited experience. valvoline, shell, castrol, redline, etc. I even use walmart supertech synth engine oil in my cars for winter time use. As you can imagine, there's a lot of 'discussion' about fluids and when you begin to vary from what your manual suggests, you assume some risk. Often minor, but who really knows?
consider a brake fluid flush and the front diff's fluid. maybe even use a turkey baster with a hose to pull out some power steering fluid but, maybe only if it looks like coffee. maybe a bottle of Techron through a tank of gas. take a look at when the car gets spark plugs. read the manual about use of the spare tire and towing the car. that's all I can think of - congrats!
is there a good ground from the engine? the plugs still need that return path. or maybe a CPS problem?
- 11 replies
- no spark
- ej205 to ej255
- (and 4 more)
miles touched on a good point. Ask in a new thread for recommendations of a shop near Boise. You not only could find someone to handle a pre-purchase inspection for you, but sometimes a shop may know of a regular customer with a decent car for sale. I've even seen some shops with bulletin-board posting of cars for sale. At least there'd be a good chance the car saw some care during its life. 'Network' with your fellow churchgoers, PTA parents and teachers, neighbors, even relatives in retirement communities, etc.
OK, level seems OK. (left side is driver's side in the US) Is there a CEL or any flashing lights on the dash? Maybe some gummy deposits are causing a valve to stick until warmed up? Another fluid drain and fill or 2 might be worth trying. Also, some folks report success usingadditives in the trans. CRC Transmax or similar. I wouldn't expect miracles if something's actually broken - but the fact that it seems OK after a warm-up is kinda positive that some remedial treatment with good fluid might help. It actually takes about 3 drain/fill routines to get about 85% new fluid since so much stays in the TC.
just to be clear, and forgive me if this is obvious to you but, it isn't to everyone, the AT fluid's stick is designed to be used with the car idling. It will show a higher level if check with the engine off. It's the stick on the lekt side by the firewall. The stick on the other side is the front diff. Sometimes those have confused people as well. Also, any work or wrecks to the car before this began?
I read once of a guy with similar symptoms (but in an STI) and he discovered mis-routing of breather and PCV hoses. It caused a vacuum in is crankcase. He even heard gurgling I think from the dipstick tube? maybe pull the stick and check for the feeling of a vacuum from the tube - or if the pressure light goes off/changes? weird I know but, easy to check.
