105
^^^ hmmm, I think I read where there was a weight limit on how much a canister could weigh. maybe find that value and pull the canister and weigh it? Saturated cansiter would weigh a lot more than 'dry' I'd guess. maybe the gas tank's vent valve stuck open would lead to this? Or a malfunctioning Purge valve?
- 7 replies
- hesitation
- outback sport
(and 1 more)
Tagged with:
^^^ look for oil in the plug tubes too. might not hurt to try a tank with a bottle of Techron, or maybe SEaFoam too.
- 7 replies
- hesitation
- outback sport
(and 1 more)
Tagged with:
I just don't know. The PZEV could make it different/unique. I did get to converse a little with a tech about the issue of 'spiders' or something causing pressure to buildup in the canister - preventing easy refueling. He had seen 2 Foresters with re-fueling problems and he said one was definitely spider-'stuff- he had to blow out. Evidently some cars have a valve on the Drain-side, some have a little box with a paper filter? maybe both? , I will probably be able to find most of the components if I can get the car into my garage - just don't want to miss anything. I've even considered just locating the drain line from thew canister and disconnecting it from any Drain valve, and building a screen-wire cylinder to attach the end, then just poke/secure that up outta the way. let the spiders and the ECU have a dead drain valve and some hoses/filters for their amusement. The problem , I THINK (it's just a theory) is, the dealership is 17 miles away and if the ECU runs a Purge before the car gets there, the pressure would be relived in the canister, That's why it never fails for the service writers over there. This last time, I took video immediately after we picked up the car of my BIL unable to fill the tank without it continually shutting off. Dropped the car back at the dealership - they say they need the Regional guy. probably want to make sure mother Sooby will pay them for 'exploratory surgery'. But, I can GUARANTEE you, this will happen again if there is ANY opening into which these spiders can crawl. The only way to fix this is, a perforated surface like a cylinder of screen-material on the end of w'ever hose or nipple or cylindrical boss is the final atmospheric opening. Once, they told my 85 year-old MIL that she needed to spray bug spray under her car regularly! that is BS.
Looking for pics and/or diagrams showing the components, layout and, ideally, location on vehicle, of the components connected to the charcoal/carbon canister. Where the drain line goes, if there's a drain valve where it is, where the ultimate end allowing access to the atmosphere is (hose end or filter box or valve nipple, etc.) thanx guys
well, it isn't clear the oil level is being checked correctly or on any type of schedule so, make certain the car is level, if it was just running, wait 5 minutes or more, pull the stick and wipe it, wait a minute, insert the stick fully, then check, look at both sides of the stick. Do that again to see what the reading is on average. Consider changing the PCV valve. Whent the timing belt was doen, was the engine removed from the car or any other work done? Has the oil pan been dented? what brand and weight oil is being used?
- 7 replies
- P0420 P0028
- P0026
(and 1 more)
Tagged with:
Her car was in the shop again. they say they were able to fill it. I went with my BIL this morning to Hiley Subaru in west Fort Worth. It had been sitting there a coupla days. I followed him the a nearby gas station. I filmed him attampting to fuel the car. On the lowest volume part of the locking system it repeatedly clicked off. Drove it back, he showed them the video, they basically said they can't do anything withoit the regional guy. so, kinda disappointing. Spoke a a tech there while waiting around. He explained where a coupla parts are, he said they had a coupla customers with spiders and one ladies car hasn't come back after a valve was replaced. So, maybe know more about what's happening later on. 2 things come to mind here; the highway trip of 17 miles or so MAY be clearing the problem such that the dealership isn't guranteed to see it. And, maybe day-night cycles or some other issue with sitting around is contributing to the problem.? The tech i spoke with said the 2 cars he worked on was definitely spider webs/debris. __________________
no hose clamp - get a Viton metric 928 o-ring. There is a 'dimple' on the tab on the cap that seems to be there to limit rotation travel - carefully approach it. It seems like it would be easy to ramp it up in the plastic lug and put stress on the tab. You'll see or dig around the Forums for images/instructions. http://www.subaruoutback.org/forums/110-gen-2-2000-2004/41182-symptoms-fuel-pump-o-ring-problem.html
seems more like HGs but, if you saw mal-functioning fans, that needs to be investigated I'd guess. If they sre intermittent due to -what? - a failing relay or bad ground conections. w'ever - you will def. get overheating when stopped. has the car blown coolant OUT of the overflow tank? Does the car have a working OEM-style thermostat?
definitely inspect the fuel pump assembly - cheap/easy insurance. but it does seem like you have typical HG problems. There is a chemical test from the parts stores but people have had variable results with it. best to use if you see bubbling in the coolant. You might email Blackstone labs and see how much/if they can sell a test for bad HGs. probably need to sen din a few ounces of coolant.
