105
you must have a fan (probably 2) going at idle with the a/c on. That can definitely be a problem. Sometimes people report decent cooling on the highway, warm temps when they are at a stop light. That's because the fan isn't working and clearly there's air moving thru the condenser at highway speeds even with a bad fan. of course, there are plenty of other ways the system can fail. Often, the 2 o-rings at the compressor slowly leak out enough refrigerant to prevent the system from working properly. Or pressure sensors can go bad, etc. read here; http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/43428-diy-c-air-conditioning-leak-refrigerant-repair-5-less-15-minutes-less.html
most likely, a low charge due to leakage at the o-rings on the compressor. a pro would recover the refrigerant, swap the compressor o-rings, maybe the guts in the schrader ports, then, evacuate with a vacuum pump, check for leaks by observing if the vacuum holds, then charge the system. they also have 'sniffers' and other methods they can use to test for leaks. You could have a leak in the condenser from a rock, a bad hose, etc. Some people re-charge using refrigerant with UV dye to help find the leak. many people try a DIY approach like this; http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/43428-diy-c-air-conditioning-leak-refrigerant-repair-5-less-15-minutes-less.html?highlight=diy+refrigerant+o-rings
well, it certainly 'could' = g'ma. interior detailing, maybe some seatcovers (covercraft/katzkin) etc. If she's involved in picking rims, maybe tint, maybe some other items -it'll feel more new-ish to her. At present my adult kids are driving; oldest daughter 1987 (yes 87) Volvo wagon, middle daughter, a 2010 Mazda 3, youngest 2006 Impala their first cars were; late 90s Toyota Camry sedan, 1990 Maxima, 1996 Maxima My kids were thrilled not to be walking....ymmv
^^^ + 1 for tint, rims (check out Rota for 'affordable' models, also TireRack.com and I think Discount Tire have utilities at their websites that let you load an image of YOUR model car and 'try-on' rims) LED lighting upgrades and xtras. new head unit - prolly new speakers, check Crutchfield.com or any experienced posters that reply here would be good resources too. (I raised 3 daughters, they also helped pay for their cars. I split major repairs with them, but they had to pay for normal maintenance and tires, etc.)
best bet is to pay for a pre-purchase inspection. The mechanic should make a list, and perhaps on the side have a conversation with you as to what needs to be done immediately (maybe a set of tires, or timing belt job) what you can live with ( a little leak here and there, burned out dash lights) and what you may want to save up for (struts or some bushings ) That might also give you some ammo to negotiate a better price. Ask for a shop recommendation in a new thread. maybe someone here knows a place near Burlington.
Wife's car got a new battery. VatoZone Gold lasted 3 years 9 months, not bad for this part of the country. anything over 3 years is good. But, only had $40 of pro-rated money. Decided to get a Super Start Extreme from O'Reilly's . With a slight difference in price and a rebate (well - gift card) it saves me maybe $5 ,and , the battery is sealed/0 maintenance. Though it may be getting weak/old now, I really like the one in my WRX. I think there's less corrosion because of the way it's vented ? The pos. terminal in the Outback was a mess, I swapped it for anew terminal - AGAIN. Freaked me out for 30 seconds. Didn't want to start until I locked/unlocked it with the remote fob.
I recall that some older soobs had issues with the Engine Temp Sensor keeping the car in 'choke' mode - fooling the ECU into thinking the engine was cols all the time. And that will usually not throw a code. On your car, I think its the 2 wire sensor. Mounted near a one wire Coolant temp Sensor. vacuum gauge probably comes with a few attachments and instructions. Check the web and youtube too.
You may be wasting money running the premium, but I don't see how it could be harmful. I certainly am no ethanol promoter, but I doubt your car would be harmed by using the regular with 10% or w;ever ethanol.
- 16 replies
you can buy Techron otc at parts stores as well as Walmart, maybe target, etc. Just use it once as instructed. I use it maybe every year or 2 before an oil change. Some years I use SeaFoam instead. I think they have an edge on some of the other additives but, i have no experience with Lucas. Certainly though, don't use it in every tankful. (is that what you said?) that money is better spent on good gas plus, over use might throw the A:F ratio off, dilute your oil or stress the cat conv. Don't over-inflate your tires too much, You lose material in the center and therefore are not really 'saving' money overall. Plus, it can be dangerous. 2-3 pounds over is OK, maybe add 1 or 2 to that if fully loaded-out. Any weight you can remove from the car will help and don't drive with the crossbars on the roof. You said you chaged the knock sensor. Any chance you over-torqued it or the cable is stressed? Most folks wire brush the mount area, make sure the cable is positioned the same direction as the stock sensor. I THINK the torque is 17 ftlbs. (anyone?) more might crack the sensor. Both of my soobs see 95% surface streets and they both average 20 mpg. My 06 WRX goes 11 mile to work, 11 miles back home, rarely any highway. Our 03 H6 sees even shorter 'grocery getter'- type trips with rare highway use. It gets 20-21 mpg. It never got better than 26mpg on a road trip/vacation. AND, they both run Premium.
- 16 replies
if you could get freezefram data to see the fuel trims, that might help you decide if there's still some problem to track down or not. I assume the tire size is the the same as listed on the door card? A bottle of Techron 'could' help restore the injectors spray PATTERN. But i wouldn't use any fuel additive in each tank. make certain the plugs are proper for the car and all the grounds are good. NGK is best for plugs and plug wires. Maker sure you use the OEM type thermostat and that someone hasn't pulled yours out of the car. Make sure you aren't dragging any brakes. make sure the wheel alignment is OK. those could be small 'parasitic' losses to mileage. BUT, I think you are close to the best the car can do given your usage. The short trips means a higher total proportion of engine time is run when 'cold' and that means injector pulses are in 'choke' mode.
- 16 replies
