1 Lucky Texan
    105
  1. the manual advises to tighten the axle nut with no weight on the tire. Did you torque it sitting on the ground or in the air? I put a big screwdriver in a rotor vane and 'buck-up' against the caliper to torque the axle nut. no harm in checking the nut to make sure it is still staked in place.
  2. what's the source of the replacement axle? MANY people have had problems with rebuilt axles, sometimes even new aftermarket axles.
  3. if it does it reliably after you start and idle in the mornings, you could 'probably' prove it's the belt again by spraying something like this on it;
  4. more likely than you think! http://www.lonestarrallycross.com/
  5. you could bypass it by connecting the hoses. No heat for the summer. use the time to save up/shop for new part.
  6. is the CEL on? post ths codes for us. Do you mean the engine is missing? or is there a vibration in car? does it jerk when parking in a parking lot? describe what's going on with a word other than shuddering.
  7. PB Blaster is unlikely to affect rice. (test ii with some rice from the kitchen?) anything I can think of to 'dissolve' rice is too risky for the metals. (Hydrogen peroxide from the beauty shop, liquid Plumber, etc.) borescope is a good idea.
  8. weird (oh, and sorry it happened to you) any dents in the oil pan? the oil pressure thing is weird, wondering about a cracked pick-up tube. maybe a different engine IS a good idea.
  9. what code was set? checked the cam/crank timing yet? also, confirm the big IAC hose is attached to the intake.
  10. I've read in the past that CardOne re-builds the re-mans for Subaru dealerships but, I have no idea how that could be confirmed. If he had bought a NEW Subaru axle, it may have had green paint on it.
  11. MUST have pulses from crank sensor. Missing 'lugs' on the crank sprocket, bad CPS, ignitor, etc. But, seems like you could have a bad fuel pump or ?
  12. I *borrowed* this from another forum - maybe it will work; 06-09: How To Read Diagnostic Trouble Codes (DTCs) How to Read Diagnostic Trouble Codes on 2005 thru 2009 Subaru Legacy and Outback The 2005 thru 2009 model year Legacy and Outback can display Diagnostic Trouble Codes (DTCs) directly on the dashboard. No scan tool is needed. No jumper wires are required, and it is not necessary to count blinky lights. The codes are displayed in plain text on the instrument cluster. Trouble codes from the ECM (Engine Control Module), TCM (Transmission Control Module) and ABSCM/VDCCM (ABS or VDC Control Module) are displayed. This procedure was distilled from the FSM. The English translation in the FSM is not very good, so I have attempted to make it easier to follow. The FSM has this procedure in the Body Section, Instrument/Driver Information, Comination Meter System chapter. Some notes before starting: - I believe this procedure will work for all 2005 to 2009 Legacys and Outbacks. However, I have only tested the procedure on my car, a 2007 Outback 2.5i automatic. - I don't know of a way to reset the codes without a scan tool. Disconnecting the battery may or may not work. - Exactly what you will see depends on what type of display your car has. There are two images of tables below, one for the Normal display and one for the Multi-Information Display that is found on Turbo models. The Procedure Starting condition: key off, headlight switch off. Steps 1 through 7 must be performed within 10 seconds. 1. Turn key to ON position. This is the normal running position, the click just before starting, when all the lights on the dash come on, but before you twist to START. Don't start the engine! 2. Within 3 seconds, turn the headlight switch ON. 3. Press the Trip/Odometer button 4 times. 4. Turn the headlight switch OFF. 5. Press the Trip/Odometer button 4 times. 6. Turn headlight swtich ON. 7. Press Trip/Odometer button 4 times. At this point, the DTC display will begin. 8. Turn headlight switch OFF. Not necessary for the procedure, but your display may be dimmed and hard to read in bright sunlight. Besides, why drain the battery? The DTCs for each module will display in order: ECM, TCM, ABSCM/VDCCM. Press the Trip/Odometer button to cycle between modules. The FSM states that the display will cycle between modules automatically every three seconds if the button is not pushed, but that did not happen in my car - I had to push the button to cycle the display. For each module, there are three display states: - Receiving DTC from module (blinking "P" or "C") - DTC detected & displayed ("P" or "C" followed by 4 digits) - No DTC found ("P" or "C" followed by "----") If there is a CAN (Controller Area Network) bus communication error, you will see only "----" in the display. Basically, that means that the network in your car is broken. That will need to be repaired before anything else can be done. See the table below that applies to your car, depending on which type of display you have. Notes - TCM error codes will not be displayed for cars with manual transmissions. The TCM display state will remain in "Receiving DTC" (blinking "P" on display). In my case, my car is an automatic, but the blinking "P" remained, possibly because I have no codes set. - To cancel the DTC display, turn the key to OFF. - If the engine is started, the DTC display will remain until the car starts to move. (I did not test this) - Past DTCs that have been repaired will be displayed until the engine is started 3 times. (I did not test this) Display Tables Normal Display Multi-Information Display from; http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/19053-06-09-how-read-diagnostic-trouble-codes-dtcs.html
  13. IAC air tube under the intake might be loose (guessing a 93 has something like that?) crank/cam timing could be slipped dirty/gummed-up throttle body
  14. if it clicks at low speed, have someone pace the car in a parking lot and do left, then right circles. In general, if you hear a Rzeppa joint clicking, it will be the one on the inside of a turn. The articulation is greater due to the Ackerman angle. But that is a good point above about rebuilding both - plus, you'd have the opportunity to swap sides - the little-used reverse surfaces will now be getting forward wear, might extend the life of the axles.
  15. got it is the concern on the cat/O2 due to a P0420 code? if so, you might read here; http://www.subaruoutback.org/forums/66-problems-maintenance/49537-p0420-diagnosis.html
  16. cheap sports cars are often handed to 'kids' that may be abusing it. As said above, folks like me (an adult that tries to respect the car's mechanicals and doesn't side-step the clutch or try 3k rev clutch dumps to launch) are rare WRX owners. Not unique, just hard to locate. Shopping for ANY cheap sports car would require a LOT of extra diligence in determining who has been driving it and how it was treated and maintained. Maybe getting in good with some local mechanics/tuners would help you locate a car that at least has visited a capable technician once in a while. IMG_3120 by alckytxn, on Flickr
  17. what rooster said - best to do some research (which you are doing here, good first step) INSPECT everything, suspect all fluids, hoses and maintenance items, make a list of what needs help NOW (safety and reliability stuff) what you can live with (small fluid leaks, rattles, maybe a passenger window that won't roll down, w'ever) and the big items you need to save-up for. but each of us would have our own lists that would vary from each other. You could also take the car to a mechanic for an inspection and work from his list. Consider posting a new thread asking for a shop recommendation near you in FL.
  18. 209K miles trans guys - can it be repaired? of course. I would just shop for a replacement used trans., Inspect fork, flywheel, clutch, change TOB w'ever when you install the new trans, fresh non-synth GL-5, drive for another 100-200K miles. done and done
  19. those tires are all the same brand/model/size right? very important on AWD cars. PCV valve clean or replacement might be a good idea. is that car 4 wheel disc? if so, adjust the rear parking brake star wheels. maybe replace the little shoes inside the rotor. fuel filter many cats get replaced when the real issue is an exhaust leak or some other issue throwing the a:f ratio off. But certainly a car as old as yours could have a bad anything. Just make sure. on plugs, plug wires and O2 sensors, NGK is preffered (rear O2 might be OK if generic, not front though) if you break into the cooling system, OEM style t'stat ONLY;
