105
Gates is probably the most popular aftermarket belt. very popular, never read of an issue with them. That said, almost everyone finds a mark on the back that is half a tooth off. sometimes, there are 'pending' codes. If used scanner and none show up - then there are none. But, some codes need to hit twice to set the CEL. sometimes knock sensors and Engine Temp Sensors (not the temp gauge sender) are bad without setting a code. maybe a minor vacuum leak, or some oil in a spark plug tube, etc. , might not set a code if minor.
yeah, it's a longshot but, just wipe it down with a paper towel(I was chasing a problem oand wiped mine down, tested the the 'stuff' with a magnet and several pieces stuck. I guess the theory is, some collected metal dust 'could' make signals from it marginal. - again, longshot). never hurts to occasionally re-seat an electrical connector.
unless both sides show some evidence of failure - don't do both sides. If the other side rocks up and down or sounds or 'feels' crunchy, maybe do them both if you have the funds. But, if the other side isn't 'bad' or, even if it has some slight movement, just drive on it and save-up for that side's repair. It would be unusual for both sides to be equally bad. if you can do any DIY work and need to save some money, you could consider removing the knuckle yourself and taking it to a shop. You buy the parts too from NAPA, RockAuto or Amazon or an online dealer like subarugenuineparts.com or others - take everything to the shop.
I don't guess you removed the intake hose from the IACV? I've read it's an easy thing to forget or have fall off when engine work is done. you might try cleaning or replacing the crank sensor. I don't think it's common , but I have read on another forum about 'filings' collecting on the crank sensor causing issues. Maybe opening up the front has 'disturbed' it enough to cause issues?
I've been thru these theoretical discussions before. I'm in the camp that the actual radius (distance from hub to ground) in use when the car is rolling is what matters. If that's true, inflation values could be manipulated (within limits) to eliminate TB. Of course, SAFETY and handling could be compromised. sometimes, you can find used tires on ebay, or have a tire 'shaved' at a performance shop. I would never have 2 tires shaved. The money spent and value lost in tread wear combo is too much. better to get 4 new tires. HOWEVER, as mentioned,(on a car with open diffs front and rear) with 2 worn tires that match EACH OTHER, 2 MATCHING new tires can be put on opposite corners and everything should be fine even if new is different from old.
Could you demo the problem if you took your mechanic for a test drive? he might have an idea.
- 12 replies
- Automatic
- transmission
(and 1 more)
Tagged with:
I have read of a person that had an engine installed and there was some mix-up with PCV and breather hose routing that lead to odd symptoms one of which was the oil light coming on. He also could hear 'gurgling' in the dipstick tube when the engine was running. can't recall more details. Definitely, you must be on level ground, pull the stick and wipe it, and wait several minutes. 2 minimum, before checking the level.
new air and oil filter and oil in the wife's outback today. Cleaned the battery terminals and inspected around a little. probably swap out the cabin air filter in a day or 2. Detected extremely slight movement rocking left front wheel up-down. No crunchiness when feeling spring and turning wheel. I'll have to monitor that closely.
if a car is otherwise running well, it's almost always a good idea to read and record the code(s), then clear them and see which and how quickly code(s) return. I have had a failing battery set a handful of spurious codes. And certainly, there could be a bad ground connection or the sensor itself is bad internally.
^^^ great point - maybe why I've never seen this problem is because I usually sneak up on full torque in stages. kinda like; hand tight - very tight - final torque. always in a star pattern but usually with different start-point/different order each time.
- 27 replies
- lug nuts
- broken studs
(and 1 more)
Tagged with:
my dad had a Studebaker once. oh - wait, STUD-breaker nvrmd
- 27 replies
- lug nuts
- broken studs
(and 1 more)
Tagged with:
does anyone else feel lug nuts should be replaced after a several years? I have replaced them on our 03. They get a lot of 'cycles' with tire rotations. And they sorta 'gall' on the contact area.
- 27 replies
- lug nuts
- broken studs
(and 1 more)
Tagged with:
what is the likelihood of sabotage? good relationship with neighbors? upset ex-spouse? when I went to the track, I was advised to take my torque wrench to check lugnuts after my first run - they were fine. Also, is this more likely with aftermarket wheels? Maybe someoen has put wheels on that are not 'hub centric'.
- 27 replies
- lug nuts
- broken studs
(and 1 more)
Tagged with:
