105
	does anyone else feel lug nuts should be replaced after a several years? I have replaced them on our 03. They get a lot of 'cycles' with tire rotations. And they sorta 'gall' on the contact area.
- 27 replies
- lug nuts
 - broken studs
					(and 1 more)
Tagged with:
	what is the likelihood of sabotage? good relationship with neighbors? upset ex-spouse? when I went to the track, I was advised to take my torque wrench to check lugnuts after my first run - they were fine. Also, is this more likely with aftermarket wheels? Maybe someoen has put wheels on that are not 'hub centric'.
- 27 replies
- lug nuts
 - broken studs
					(and 1 more)
Tagged with:
	what about the stuff they use in water systems in RVs ? or; http://www.orisonmarketing.com/IceclearAF.html In the past, i used an environmental test chamber that use liquid CO2. You have to find the cylinders with the siphon tube. maybe a gas company could make up a smaller cylinder for you. Still, there's gonna be handling/usage problems. are alcohols too flammable? -100 C or colder I think.
	get the PCV valve and hoses changed/cleaned too. High crankcase pressures will exacerbate oil leaks. After that, it may be better to keep topping the fluids off while digging for more serious issues. If the engine has to come apart, or be replaced, no point in putting new valve cover gaskets on now. Compression/leakdown tests may be a good next move. Also, shopping for an engine from the junkyards.
	just changed intake air filter, oil and filter, and new trans oil in the WRX. cleaned batt terminals and checked fluids. Inspected brake pad thickness, Think I'll put a new set on all-around in October. Need to change the cabin filter and have Discount Tires rotate and balance the wheels. should be good for the summer after this! also, need to do some of the above on the Outback.
	40 is right on the edge I think. Driving at highway speeds, I think it's a beast when I put my foot down. But outta the hole and anywhere up to 45/50, not so great. maybe no worse though than a typical 6 cylinder. Some of the other 'utes' have a lot of torque available, perhaps built with more of an eye towards towing? - I dunno. If the one you drove has been running with regular octane fuel, that's at least a part of the problem. ours is a very nice 'medium cruiser'. It has it's quirks with wind noise and downshifting at very high speeds - otherwise, no complaints.
	yeah, drain and fill only gets about half the total fluid. drain/fill/drive repeat 2-3, times gets 80-90% new fluid. you 'could' try a different brand of fluid and/or a CRC or Lucas additive. definitely go thru GG's list especially number 13. I'd wait if possible til GG replies to this thread though. he has a lot of experience. I only read about the stuff he and other gurus do.
