1 Lucky Texan
    105
  1. uh - just messing around chief. Nothing personal. I see no reason there couldn't be some corrosion or flaky plating or even a bend in the strut rod making it 'give way' a little and move. there's supposed to be some nitrogen gas in there and even a rise in temps could increase the gas pressure or free-up some gummy oil or something.
  2. Even though soob bearings can have mysterious failure modes, what you describe is one common way a right (probably front right) wheel bearing could begin to fail. certainly have other components check/replaced as mentioned. an infrared remote thermometer might show one bearing/hub 30 degrees hotter than it's mate after a highway run.
  3. was there a Sorcerer or some magic beans and a cow involved somehow? riddle - what happens if Pinocchio says; "My nose will grow now!"
  4. fairtax, is that the same as an 'input shaft' bearing? seems like in the old days, noise clutch in vs noise out would help decide between throw-out and input shaft bearings but i can never remember which way. I don't have the experience you guys do.
  5. I dunno on an '11 , but a lot of soobs have shown the ABS system to be VERY sensitive to voltage and is often the first hint an alternator is going out.
  6. well, I don't know what instrument you're using but, an ohmmeter supplies its own current and isn't used on a powered circuit. Sounds like the meter is just confused with the power in the line and the slight drop across the connection? kinda weird as there shouldn't be a lot of current with the ignition just at ON. I'd be tempted to do all my resistance testing with the neg batt connection removed. Also, try reversing the leads on your testing. Sometimes corrosion can act like a diode. not commonly, but possible.
  7. carbon build-up in the cylinders could lead to knock - but if the sensor isn't pulling timing, it isn't knocking. one experiment to try, clear the computer with a battery disconnect after filling with high octane. maybe try a coupla tankfuls. If the problem seems better, may be a 'real' knock issue. but from what you say - ECU seems suspect doesn't it? Or the connector to it w'ever
  8. well, I'm betting the book has an "i" for inspect at the 30K service point - but either way, yeah, they are now in the tank with the pump. not sure whicch models/years first went into the tank;
  9. knock sensors are cheap. Is yours cracked? anyway, if you replace it, it can be important to orient the part so the cable dresses away at the same position as stock. Some people have put them on and the casting pushes on the bottom where the cable comes out and cracks it again.
  10. maybe I'm not following but, are you complaining about vibration when stopped in gear, that goes away when you shift to N or P ? that is often poorly rebuilt (or worn ?) front axles. a 96 almost certainly does not have its original axles.
  11. seems dicey. Some soobs, older models mostly, do have a reputation for piston slap noise. But what you're describing seems worse. if the engine was ever overheated, you may be buying a ticking time bomb that will throw a rod. But, a loose TB tensioer will also sometimes let the belt flop around, that can sound like a knock. You could pull the timing covers and look for an abraded spot where the belt has been whacking the cover I guess.
  12. be careful; http://www.youtube.com/watch?v=enxj-2rPJLQ http://www.youtube.com/watch?v=Ou7_tiKTGAY
  13. OBDII would definitely be on an emissions sticker under the hood or somewhere in the engine bay. similar to this - maybe someone else will know a better clue.
  14. ? which one do you want? Is this truck going to be 4WD? if not, no contest off-road, Subaru wins. but, if the 'stuff' you carry is huge or dirty, the truck wins. If you really only haul dirt or giant stuff once or twice a year, the fuel savings will pay for a rental vehicle - or borrow a buddy' truck and buy him some beers w'ever.
  15. yeah, I was kinda wondering if, in the past, someone had put the wrong part on - perhaps from a junkyard?
  16. what car? newer ones have HBAs and are a little friendlier for DIYers. (at least, the HBA I did on a Chevy was easy) even if press-in, some folks buy/borrow/rent hub tamers w'ever. Myself, I'd probably pay a shop to press it in.
  17. most likely - bearing less likely - front diff other possibilities - brakes, axles
  18. got it. You might consider slotted only but, as fast as you will go thru brake components, you'd likely change rotors before any cracks showed up around drilled holes anyway. someone at NASIOC might have experience with the ebay parts. I'm not running a car like you are but I've had good advice from the guys at http://www.knsbrakes.com/c/home
