105
weird can you post any pictures of what you're seeing? maybe start pulling breather, PCV, throttlebody and other lines and look for coolant/oil contamination. Is there signs of coolant in the IC? Also, compare all 4 plugs to each other. maybe the guilty cylinder's plug will look different. Once you feel confident it must be a head gasket - you know what needs to be done. Ivan's post #7 seems likely. The oil return passages have lower pressure so, oil getting in coolant might not happen. Just coolant into oil.
There's a huge thread at NASIOC dealing with "Scotty's cocktail" to help with synchro problems. It won't repair a car, but may reduce some of the clashing. Most people say stay away from synthetic, but Redline Shockproof may be an exception due to the odd formulation. I'd say, just try some fresh, name-brand but not expensive, NON-synthetic GL-5. If that doesn't help, maybe investigate the cocktail?
any CEL codes? possible engine temp sensor or knock sensor problem. Most other issues might set a code.
96 might need new wires. OEM preferred. Aftermarket is dicey - maybe NGK or Denso specific for Subaru OK? maybe some dielectric grease to coat the inside of the boots. NGK or dealer supplied plugs SHOULD be pre-gapped. I'd check them to be sure though. If you get platinum or Iridium - be extremely careful as the iridium tip is easily damaged with gapping tools. different length/size extensions. I've read of some folks using a length of tubing to help start plugs but, The 2 DOHC cars I swapped plugs on felt confident as for starting the plugs. Widely different opinions on use of ant-seize or oil on the plug threads - your call.
there are numbers for the entire unit. there's a lef and a right side. The torque values are huge and, with stuff just 'snug', you are gonna want to drop the car and bounce it, crawl under with it on the ground and torque it to full-tight. Then , drive it around for a few days, re-torque again. Wouldn't hurt have it aligned - or wait till you get new tires and align it. while I went with poly, there's a DIY around here somewhere for the lca. Yeah, you might look here for some idea of what's involved; http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/48910-lower-control-arm-rear-bushing-transverse-link-replaced-prothane-03-outback.html
that LCA rear bushing 'transverse link' is THE single most heavily loaded spot that transfers tractive and braking forces to the body of the car. You may wear-out tires faster too. To do it right is a little pricey. Do it cheaply (with poly bushings) and you have quite a bit more 'fiddly' labor and will also have a lot more harshness. If you put the car on jackstands and push pull the rear of the lca, does it hit the inside of the mount? if the fluid is leaked out, they still sorta work OK, but if rubber is gone - I could DEFINITELY understand them making noise. agree with GG on axles. And often, people go weeks/months with them making noise - but they will fail eventually leaving you stranded. Outer joints usually 'click' though - dunno about knocking. as for any other ideas to check; broken springs can be hard to spot, double check anti-sway bar endlinks and mounts (and for breakage), I guess struts/strut mounts could be a source???
well, as for just working with some WAGs, I'll offer a couple; double check the 'transverse link' bushing. Sometimes called the front lower control arm rear bushing. as a wild experiment, you could swap axles left to right in the front. If the inner tripod joint is making the noise, it will make it on the other side now - or possibly stop with almost new wear surfaces in play (cause, only reverse would previously be wearing the axle.)
how many miles on the car? is it due for a timing belt? could have slipped timing by a tooth. I know you said you could not find a vacuum leak - but you might try using a vacuum gauge to see what it looks like when it stumbles at idle. I wouldn't discount the possibility of a bad knock sensor either since you have low power.
if the crank was at the timing mark (not the triangle/arrow - never the arrow) then there's no way the valves can hit the pistons. But, if the arrow was at 12 or 6 o'clock, then you could have bent a coupla valves. A compression or leakdown test should confirm. look for any hoses that didn't get put back on or have slipped off. Especially the IACv one that goes underneath the intake.
