105
hope they get it fixed-up. "Infant Mortality" is a real effect with manufactured items and often, after the first glitches are taken care of, reliability settles down. if you think the issues are extreme, check into your State's Lemon Laws in case you need to make a claim. Subaru may just be in a hurry, I read they were down to 6 days of inventory.
First Time Subie Owner
1 Lucky Texan replied to Grim's topic in Meet n' Greet. Your USMB Welcome Center
Grim, there will be quite a bit of suspension stuff available for the car. You might check out www.nasioc.com a tune may help a little, but the turbo cars can benefit most from tuning. at www.subaruoutback.com, there's a user west_minist that has tuned several folks' cars. he has a website, http://xtremeracingtuning.com/ if you want to mod for offroad, plenty of folks here could help with that. -
OK, most of the symptoms you mentioned match a well known issue with that generation. There can be a 'flare' when accelerating at highway (actually, fairly high speeds in my experience - 75+) speeds. as a test, try a battery disconnect reset (write down your radio presets, disconnect the battery overnight, or, disconnect, step on the brake pedal, wait 10-15 minutes w'ever, reconnect. Do this just before a road trip, or other highway usage. If it helps the issue, it is typical for that generation. If not, you may have some other problem. Years ago, I posted about this with my 03. It was already a known problem. The TC will unload, then there's a downshift flare before the lower gear engages, then BAM, it can be terrifying. Can't be good for the drivetrain either. After I learned about it, always did the reset before road trip. I dunno how often , or if ever, you will need to do it if you are always driving at extreme highway speeds. you may of course have a different problem.
2-3 ideas Automatic? you have a FWD fuse selection slot under the hood.Use that with mismatched tires. check ebay, craigslist, etc. for a used tire the same model as your other 3 and near them in wear. have a new tire shaved down to the average of the wear of the other 3 If you DO NOT have a viscous rear diff, buy 2 tires but run them on opposite corners of the car.
yeah, really doesn't seem like a sensor/ECU issue, seems like something more 'physical'. as said, triple check cam/crank timing. Locate the 'tooth count' for that engine. Bring the crank/cam marks to their 'belt install' positions and count the teeth between everything. Something may be a tooth off. Wonder if a 'dropped' valve guide could come-and-go??? maybe some odd vacuum leak comes-and-goes??? - maybe try some vacuum gauge readings - may have to rig a way to do that while revving/driving?
New to the Forum from Tampa/St. Pete
1 Lucky Texan replied to gulfsidebo's topic in Meet n' Greet. Your USMB Welcome Center
not in your area, but welcome. These guys as well as some folks over at www.subaruoutback.org have helped me quite a bit. My '03 Outback has been passed-along to a family member but is still running every day. -
I'm Kind of Awesome
1 Lucky Texan replied to Bojib's topic in Meet n' Greet. Your USMB Welcome Center
welcome aboard! check-out www.subaruoutback.org too - I am a former Outback owner, and have had great help from that and this Forum -
take care of your cooling system, tires, and timing belt system and you should be good for a long time!
Newbie from Kentucky
1 Lucky Texan replied to Mccaw64's topic in Meet n' Greet. Your USMB Welcome Center
some WRX aftermaket stuff may fit on the car so, should be able to make it corner flatter and tighten-up suspension. Car likely needs struts anyway so, line-up some springs and other bits for it. sounds like you might want a slight lift??? although pricey, rims can add a lot of personalization to a car. make sure to keep your tires all the same brand/size/model/wear to protect the AWD. Keep the cooling system in top shape and make sure the timing belt system has been properly serviced with Japanese parts. overheating, mismatched tires and broken timing gear will kill a Subaru quickly. -
fantastic - please share the name and location of the shop, could help someone in th future.
