105
if the crank was at the timing mark (not the triangle/arrow - never the arrow) then there's no way the valves can hit the pistons. But, if the arrow was at 12 or 6 o'clock, then you could have bent a coupla valves. A compression or leakdown test should confirm. look for any hoses that didn't get put back on or have slipped off. Especially the IACv one that goes underneath the intake.
torque bind - at least you know the Duty C solenoid works. That's what the fuse controls. 1. make certain all 4 tires are the same brand and within 2-3 32" of wear. 2. make sure no one has swapped transmission or rear diff and has mismatched the final drive ratios if the above are good, the wet clutch pack parts are probably bad in the tail of the transmission. On rare occasions, folks have done fluid changes/flush and/or used some Lucas or CRC or other additives and made the problem better. As for the howling - sometimes the A/C will do that if overfilled. Sometimes a whooshing noise comes from the engine intake filter box if not snapped in at the bottom properly. Could be a wheel bearing or a belt or ??? Is it from under the hood? can you hear it while stationary?
first thing I would do is check the battery and charging circuit - including refreshing all the grounds and carefully inspecting the battery cables. Clear the codes and monitor how quickly and which ones come back. Also, see if you can borrow a gauge and check the fuel pressure. Additionally, next time it has sat and you think it probably won't start pull the plugs and see if one cylinder is noticeably wet with fuel. maybe an injector is leaking down. Another test would be, cycle the key to ON, not start, and wait 10 seconds, then cycle back to OFF, then to ON, wait 10 seconds, OFF, repeat one or 2 more times, then start. (the fuel pump will run for a few seconds each time - you should hear it) If it starts OK, maybe loosing fuel pressure in the rails.
even 04 soobs have them in the tank, maybe not all models though. Used to have to drop the pan on auto transmissions to change the filter - changing a filter on an assembly pulled from the gas tank doesn't seem much different. S11 Forester, part number 34; http://opposedforces.com/parts/forester/us_s11/type_17/intake_and_supply_system_turbocharger/fuel_tank/illustration_2/
