105
throttle cable may need some attention/lube. possible throttle position sensor problem i guess. can you read the codes(s) ? AutoGroan and places like that will read CEL codes at no charge. most people report good luck with inexpensive knock sensors as from ebay, rockauto, etc. Clean the block where it goes on, point the cable the same direction as the old one, don't over torque the bolt. maybe someone else will chime in with advice.
I think the best approach would be to swap in a WRX or possibly an STI engine. check over at NASIOC for lots of info on stuff like that. But, even as is, some suspension and brake and tire upgrades could make the car a lot of fun to throw around the corners. Anything can be made faster with enough $$$ ,but, 'the Man' doesn't let you go too fast on his roads, he doesn't really care how flat you can turn corners though!
very odd symptoms, maybe you have a wheel that is dragging and the small extra brake pressure is locking it up, engaging the ABS? I dunno what the symptoms would be like if there was air in the ABS lines but, perhaps you need a very extensive bleed of the entire system, or a vacuum bleed or ??? do all the wheels turn freely with no odd sounds?
after a brief search, I did see a coupla posted ECUs that ship worldwide on ebay, did you try there? a dealership may be able to at least confirm if the ECU is damaged, or just needs reprogramming. also, I THINK there may be a couple availble thru this German site - do a search using the number 22611AJ220 http://www.autoteileplus.de/
seems like a good chance that's a bad ECU, also, wiring, connector or general electrical problems I guess (did the car ever suffer a severe issue with battery connections?, jump starting?, bad alternator? and flooding in the car? rodents damaging wires?) check; http://www.datsc.com/tabid/122/OBD-Error-Code/P0604/Diagnostics/subaru/Default.aspx http://engine-codes.com/p0604_subaru.html http://www.rs25.com/forums/f72/119103-p0604-i-have-cel-can-t-find-info-anywhere-2.html
if you feel like being a real pioneer, take a look here; http://www.subaruoutback.org/forums/104-gen-4-2010-present/83865-how-fast-can-cvt-go-reverse.html definition of 'mid engine' is somewhat nebulous, but most folks claim it is when the CG of the engine lies inside the front and rear axle lines (inside the wheel base) So, technically, the old Mazda RX-7 was mid-engine, despite the engine being in front of the driver, and in front of the transmission.
if you are certain the problem is not related to the security system. And, the use of starter fluid or other tests seem to indicate no/low fuel delivery, it may be worth the effort to remove the fuel pump assembly and look for a broken tab on the cap and/or swollen/failed o-ring. It's a known gen 2 problem here in the US. but, as mentioned above, your model 04 may not be prone to that failure.
interesting - looks like that planetary reduction could be 'locked' with some kind of drop in?
no question the engineering is for forward, dunno how much running backwards would tear-up the internals. Would it cut the unit's lifespan down to days? in half? 10%?
On another forum, someone asked how fast the CVT transmission could go in reverse. That made me have the crazy idea, suppose someone could 'hack' the CVT to run its full gear range in reverse! Yeah, maybe some external fluid pumping would be needed? And custom electronics (or firmware?) etc. But, it make for interesting swaps and customized vehicle! has it been done? who's gonna be the first to do it?
