1 Lucky Texan
    105
  1. As I got older, driving my A/C-less 1981 Civic wagon began taking a toll on me in extreme heat. I'd have a headache and sometimes feel nauseated by the time I got home on +100 days. Run the A/C. make sure the system is working well, get a hose and blow dead bees and debris out from the condenser and between it and the radiator. Maybe pull some trim/glove box parts off and vacuum out the intake side of the expansion coil.
  2. You might scan for 'pending' codes after the next time it happens. Wondering if a bad spot on the TPS could do this too. I THINK you have a larger 'cap' on your fuel pump with a sort-of strainer/filter in side. While 2000-2003 legacy and Outback models have had problems in that area with a small cap and o-ring being compromised (and shutting cars down completely), the issue has never been reported in 04 . Maybe the Forester Forum would know for certain. You can get the cap and filter on-line, dunno about just the filter. Frankly, I think you have other things to check before the fuel pump but, I suppose I mentioned the above because it's a remote possibility.
  3. OK yeah, then what bratman said. Youtube videos and other info online for pulling headlights apart.
  4. Mequiars, 3M, other kits available to polish them out. Check Amazon for ratings of kits, check Youtube for demos. most folks who bake them for removal, are doing mods/dress-up stuff like; HID projector installs, 'angel eyes', painting the chrome, etc.
  5. even wiggling the wires, harness and grounds while someone observes the gauge for changes might point to a problem area.
  6. You need to confirm that the thermostat used was OEM-style. do you lose coolant or is the overflow bottle getting filled up?
  7. This can sometimes be due to old, cracked plug wires or coil. On a dry day, when you feel it would easily start, try misting the plug wires with water from a plant sprayer. If it fails to start - get some new wires (NGK or from the dealer - subies need specific resistance plugs and wires and it's best to stay with stock equip if possible) some people do this test while idling at night and can spot blue arcing from the high voltage!
  8. +1 for cardoc - he's in Austin. straight shooter, no BS. hope it's a fan - but '97 has a reputation for headgasket problems.
  9. I knew a guy that regularly drilled a hole in t'stats in his Chevy sedans (this was in the 70s-80s - I guess he was just concerned about a 'failed closed' situation ???). But, that looks like someone trying to make a silk purse out of a sow's ear! crazy
  10. I see no reason not to approach they guy and let him know your concerns about the noise. Could you duplicate it for him? Anyone can make a mistake and - I dunno - fail to install the axle pin or fully seat the stub axle, or leave a bolt loose, etc.If it IS exactly the same noise you've heard before, it might be something unrelated to the work he did and also something he may not have inspected - like a broken anti-sway bar or some bad bushing in a suspension part. Do you feel any bucking/jerking when turning tight on dry pavement? After a run on the highway? Are the tires all the same brand and wear?
  11. I wish I could get a trustworthy, capable 'someone else' to do anything significant on my cars for under $300-$500 you skated at just $92
  12. 12 year old rubber or plastic anything is suspect so, yeah, wires might be the ticket. Somtimes misting them under the hood while idling will show arcing. Could also be some oil in the plug holes from leaking valve cover gaskets I suppose. Has the car been well maintained? How old are the plugs? You might also benefit from a bottle of SeaFoam or Techron in a tankful of fuel. Might clean some carbon out of the injectors/combustuin chamber. at least you have some not expensive 'tune up' type things to try first.
  13. that gates 'looks' OK from the pic. Been running the xacstat in our 03 H6 since April - no difference detected from the original.
  14. Tribeca's have plug wires? I thought they were H6es with coil on plug? post the code from scanning for the CEL (Pxxxx) next time it happens, try jiggling the shift lever, or starting in neutral.
  15. what they said - never the arrows (triangles) the crank sprocket should have a hash mark on a 'tab' at the back that should be at 12 o'clock position.( the arrow will probably be at 3 o'clock but, could be 9 - not sure). kinda like this (your engine may look a little different);
  16. what problem do you have with the car? some people get smoother shifting with different gear oil - or even mixtures of different gear oils. buy, oil won't repair something that's broken.
  17. find a soob-experienced mech. or good dealer near you (someone here might suggest a shop in VA) and have a pre-purchase inspection done. With the AWD and the turbo - you definitely don't want to buy an expensive problem like 'torque bind' or leaking turbo bearing. Even though it's a somewhat low mileage car, the time side of the maintenance schedule SHOULD have been used. 1 month equals 1000 miles.
  18. I THINK some older ABS pumps used to go bad, but, IIRC, they would 'buzz' all the time. I think the ABS controller had to be replaced. However, my memory associates that problem with models a year or 2 earlier than yours so, I'd reserve replacement for a last-ditch effort.
