105
was the Engine Temp Sensor (not temp gauge sender) replaced? maybe run a can of SeaFoam thru a tank and/or use the SF Spray to clean the throttlebody. wondering still about the crank or cam sensors. but looks like they've been replaced? might be worth looking at vacuum readings cold/vs hot. might scan for 'pending' codes. wild ideas but, the car seems to be in the twilight zone already.
fuels trims should be low. folks start getting concerned at double digits. maxed out is very bad. double check cam timing. cars will run (poorly) 1-2 maybe 3 teeth off time. On some older cars, there's a commonly corroded/loose harness/connector in the back on top or near the charcoal canister. On newer cars, the valve is under the hood. might be a good idea to try a vacuum gauge.
A/C issue
1 Lucky Texan replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
it wasn't great, it was a GM or Nissan I think. I just mentioned it because the guy had to create a way to remove the bolt. Is the inside of that hole threaded? There are videos showing a puller that screws into a hole similar to that one in your pic. I dunno, hope you find an approach that works. -
A/C issue
I saw a youtube video where someone had to cut a slot in a weird fastener to use a large screwdriver to remove that center fastener. I guess some are assembled with unusual fasteners for some reason. Looks almost like a plastic piece will come out and maybe some Torx bit would work but????.... -
TB schedule is 105K miles OR 105 months, whichever is first. Unless there is incontrovertible proof that the TB was done with high quality parts by an experienced mechanic, better to get a car that needs the service so YOU have control of the quality of the service and a warranty if you hire it done. search for 'torque bind' . that would be another expensive mistake to make and the problem can be (but isn't commonly) hidden on automatic transmission cars. best to have a pre-purchase inspection done. the years you're looking for don't typically have dangerously weak headgaskets like models from the late 90s. BUT, ANY older car can suffer from poor ownership or be hiding a present problem, regardless of brand. maybe someone from WV can suggest a shop for you to have an inspection done.
A/C issue
^^^ and saving recycling energy or keeping stuff out of the landfill! -
good posts, I have a tiny addition. when refilling, don't assume the distance between L and F is a quart, it's more like a pint so, sneak up on the F line 1/2 pint at at time and wait between checks with the dipstick. It's tricky getting a good reading. http://www.amazon.com/Hopkins-TF-1-Heavy-Transmission-Funnel/dp/B000EH2SPO/ref=sr_1_2?ie=UTF8&qid=1368498085&sr=8-2&keywords=hopkins+funnel that's what I use, you might want to pour slowly (especially for front diff lube) but, it works well.
Sedan rear wiper retro fit
1 Lucky Texan replied to 86 Wonder Wedge's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I wouldn't discount the possibility of putting that hole in the glass. The best drills for larger holes will be diamond cylinders (nickel plated preferred) and it's gonna be best to create a donut shaped dam around the position, fill with some thing like kerosene for a lube/coolant (water with a drop of dish soap would work) and drill with a drill press. You are actually grinding. get some similar glass from a junkyard and test/ practice 3-4 times before committing to the actual rear window. You MIGHT be able to do this with a copper cylinder, slotted a few times around the edge, and coarse silicon carbide grit. It will take longer, but will work. making your bit true and centered might be tricky. I certainly wouldn't attempt it unless i knew I could get a replacement rear window. -
maybe the Engine Temp Sensor (not gauge sender) is keeping the ECU in 'choke' mode.
- 14 replies
- Mile per gallon
- power
(and 2 more)
Tagged with:
you can make your legacy more fun to throw around the corners, but it isn't going to win many drag races with the limited performance increase intake or exhaust will bring. MAYBE some cams would help, but $$$$ and maybe less reliability? It will help a little if you can get lighter-weight wheels and remove any other un-needed mass.
I know I keep suggesting this, but I can never recall the details but, a 96 may be old enough to have the aluminum wear 'area' in the clutch-pack system that was redesigned with a steel sleeve in later years. OK, pre-98s. There's a teflon seal that leaks past a worn almunum case area that was changed to steel in 98-99 or so. could be part of the problem, dunno, http://www.ultimatesubaru.org/forum/topic/6243-fwd-fusevibration/?hl=%2B4eat+%2Baluminum+%2Bwear&do=findComment&comment=52371 http://www.ultimatesubaru.org/forum/topic/6432-starting-to-hate-this-cartranny-help/?do=findComment&comment=53865 http://www.ultimatesubaru.org/forum/topic/53178-torque-bind-problem-fixed/?hl=%2B4eat+%2Baluminum+%2Bwear&do=findComment&comment=428900 http://www.ultimatesubaru.org/forum/topic/62044-best-years-for-ej22-legacy-wagons/?do=findComment&comment=557409
