105
TB schedule is 105K miles OR 105 months, whichever is first. Unless there is incontrovertible proof that the TB was done with high quality parts by an experienced mechanic, better to get a car that needs the service so YOU have control of the quality of the service and a warranty if you hire it done. search for 'torque bind' . that would be another expensive mistake to make and the problem can be (but isn't commonly) hidden on automatic transmission cars. best to have a pre-purchase inspection done. the years you're looking for don't typically have dangerously weak headgaskets like models from the late 90s. BUT, ANY older car can suffer from poor ownership or be hiding a present problem, regardless of brand. maybe someone from WV can suggest a shop for you to have an inspection done.
A/C issue
1 Lucky Texan replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
^^^ and saving recycling energy or keeping stuff out of the landfill! -
good posts, I have a tiny addition. when refilling, don't assume the distance between L and F is a quart, it's more like a pint so, sneak up on the F line 1/2 pint at at time and wait between checks with the dipstick. It's tricky getting a good reading. http://www.amazon.com/Hopkins-TF-1-Heavy-Transmission-Funnel/dp/B000EH2SPO/ref=sr_1_2?ie=UTF8&qid=1368498085&sr=8-2&keywords=hopkins+funnel that's what I use, you might want to pour slowly (especially for front diff lube) but, it works well.
Sedan rear wiper retro fit
1 Lucky Texan replied to 86 Wonder Wedge's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I wouldn't discount the possibility of putting that hole in the glass. The best drills for larger holes will be diamond cylinders (nickel plated preferred) and it's gonna be best to create a donut shaped dam around the position, fill with some thing like kerosene for a lube/coolant (water with a drop of dish soap would work) and drill with a drill press. You are actually grinding. get some similar glass from a junkyard and test/ practice 3-4 times before committing to the actual rear window. You MIGHT be able to do this with a copper cylinder, slotted a few times around the edge, and coarse silicon carbide grit. It will take longer, but will work. making your bit true and centered might be tricky. I certainly wouldn't attempt it unless i knew I could get a replacement rear window. -
maybe the Engine Temp Sensor (not gauge sender) is keeping the ECU in 'choke' mode.
- 14 replies
- Mile per gallon
- power
(and 2 more)
Tagged with:
you can make your legacy more fun to throw around the corners, but it isn't going to win many drag races with the limited performance increase intake or exhaust will bring. MAYBE some cams would help, but $$$$ and maybe less reliability? It will help a little if you can get lighter-weight wheels and remove any other un-needed mass.
I know I keep suggesting this, but I can never recall the details but, a 96 may be old enough to have the aluminum wear 'area' in the clutch-pack system that was redesigned with a steel sleeve in later years. OK, pre-98s. There's a teflon seal that leaks past a worn almunum case area that was changed to steel in 98-99 or so. could be part of the problem, dunno, http://www.ultimatesubaru.org/forum/topic/6243-fwd-fusevibration/?hl=%2B4eat+%2Baluminum+%2Bwear&do=findComment&comment=52371 http://www.ultimatesubaru.org/forum/topic/6432-starting-to-hate-this-cartranny-help/?do=findComment&comment=53865 http://www.ultimatesubaru.org/forum/topic/53178-torque-bind-problem-fixed/?hl=%2B4eat+%2Baluminum+%2Bwear&do=findComment&comment=428900 http://www.ultimatesubaru.org/forum/topic/62044-best-years-for-ej22-legacy-wagons/?do=findComment&comment=557409
A/C issue
3 lbs. ? -
make sure all the tires are the same model and wear-level. Make sure there's no fuse in the FWD position in the fuse box under the hood on the driver's side. Then, take it for some tight circles on dry pavement to check for torque bind. should be able to idle through tight circles and figure 8s without bucking or banging.
