105
^^^ superb and succinct explanation. Was any other work done? maybe check the parts list for coolant system parts. But, impossible to definitively lay blame on the shop.
changing the 2-3 largest hoses preemptively makes sense to me as you might severely overheat before getting off the road. Ths smaller ones likely give you enough time before you go dry so, unless they are easy to get to and inexpensive, might just wait until they leak. Of course your personal situation makes a lot of difference on this type decision. If you rely on a 15-20+ year old car for critical transportation or long distances driving alone,etc. , you would want to address ANY issue that could strand you. maybe even carrying a starter, alt. and fuel pump even......plus tools lol! and repair tape as mentioned, JB-Weld, and other similar repair gear would be good to have with you.
well, maybe the FSM has some guidelines for testing sensor signals - could be that the actual sensors are OK, but a wire is broken or a pin is pushed back in a connector. Testing resistances from the ECU's connector and comparing values with the FSM could locate the problem. If the car was OBDII, live data would be very helpful. Maybe someone else knows how to get live data from a '93. If the car also struggles to rev past 5K at idle, maybe try a squirt of raw propane, or starter fluid. maybe the fuel pump is weak????
GD may have the best view on this subject, but i DO believe CAFE rules have pushed car makers to slide the viscosity scale downward in the US market. It may be worse on recent vehicles (say, 2014, 15+ ?) And it seems in other markets, the engine oil viscosities are higher for the same engines. My wife just bought a Honda CR-V and on the main forum for that car, they also show the same car in Europe with a heavier weight oil recommended. Also, your location is distinctly different from mine. I am comfortable using heavier weight oils (certainly at the 'top' number) due to ambient temps here. It is said the most wear is starting a 'cold' engine. At that moment you have zero oil pressure. The thought that I park my car for hours at work, let it sit in direct sunlight in August, then go and start it when it could be 120*F or w'ever underhood - makes me wonder if 20 or even 30 weight oil has left ANY protecting film behind in the journals/bearings. And the question is even MORE important for an engine that could have 150K miles of wear. Some Subaru engines also have had a too-small oil pump from the factory, others may recall if your 03 for instance would benefit from a different pump (anyone?) Anyway, it's a very good question, not new, but worrisome, and worth trying to get a consensus from people.
maybe I haven't kept up very well but, could this be the crank pulley? Symptoms aren't a great match - could make the steering feel heavy while slipping.....?
- 26 replies
is there a lot of red stain/debris on the hood above and parts near the compressor? that could indicate the clutch slipping.
- 26 replies
My 73' Coupe Restoration
1 Lucky Texan replied to Datsunrides's topic in Historic Subaru Forum: 50's thru 70's
I remember nothing about those sizes, but was gonna suggest Datsun convertible as my old SRL311 had a valve. -
yep, 22oz for the outback, I think my WRX is less, maybe around 18???
- 26 replies
I have read several times that the H tube or orifice w'ever can make a 'hooting' noise in an overcharged system.
- 26 replies
