105
there's almost as many approaches to the oil question as religion or politics. I'd think a name brand oil of the proper viscosity range for your climate and driving conditions would be a great place to start. If a problem comes up, or some compression or other testing indicates, just be prepared to tweak your choice a little. as for tune-up ideas, you might consider a throttle-body cleaning and/or seafoam treatment or at least a tankful with techron or seafoam. brake fluid is often overlooked, and at 160K, power steering fluid might like to be refeshed. other fluids too if they haven't been changed. might wanna check the parking brake adjustment. they are no automatic and the little star wheels in the back may need to be turned up a few notches.
filter change probably not needed. I might be tempted to accelerate my next oil change a few hundred miles but, really, a tiny amount of fuel that MAY POSSIBLY be in the filter/passages, but likely not, is not gonna be an issue after the engine gets to temp for a few minutes. unrelated though but, has the car ever had a new PCV valve? now might be a good time to change or at least clean that part and hose.
OK, if you start here; https://maps.google.com/maps?oe=utf-8&client=firefox-a&q=3811+rustic+forest+76016&ie=UTF-8&hq=&hnear=0x864e64b69a2ffe51:0xa1a81a38c3bf6c2f,3811+Rustic+Forest+Trail,+Arlington,+TX+76016&gl=us&ei=6NBZUeODIIWNygHixoCAAQ&ved=0CEIQ8gEwAA you will see my WRX. BUT, if you go north, the Google SV vehicle will follow my wife's Outback out of our neighborhood!
with the key off, you're just dealing with residual pressure I'd think. Same reason folks are told to pull a fuse, start the car, BEFORE changing a fuel filter. saves you from getting sprayed in the face. But that pressure should fall off quickly. The more rubber hoses in the system, the more they have to deflate. But the pressure can't last with the pump off. But key off, the pump should not have been running. Indeed, under normal circumstances, key on, engine off - the pump only runs for a few seconds to pressurize the system. Then it comes on of course as the engine begins using fuel after starting. not saying some kinda weirdness with the engine cleaning couldn't short out a fuel pump relay or ???? Just not at the top of list of possible problems I'd think.
I dunno, a teaspoon or so. It won't be in there long and it's just to help that first few revs until oil can be distributed normally from under the piston. The car might start anyway, but it could help it start more quickly. Also, starting with the gas pedal on the floor is the 'clear flood' procedure so, if the car has pumped in too much fuel, that should help get more air in the mix. maybe Ivan has some other ideas for what an engine cleaning could damage that would lead to a rich condition.
not sure which engine you have, in fact, others here have a LOT more experience than I do. Just wondering if the engine cleaning knocked loose or contaminated an electrical connection or wiring. Seems like after that is when the fueling problem showed up. maybe look at number 4(s) here; http://opposedforces.com/parts/legacy/us_b11/type_29/intake_and_supply_system_turbocharger/air_cleaner_and_element/illustration_1/ but, there are other ways the ECU might be confused about the A/F ratio and is trying to compensate with additional fuel. Inspect underneath the air intake for disconnected tubing too.
I'm not certain I follow everything but, if any cylinders are 'full' of a fluid, that is a hydrostatic lock situation preventing the engine from turning over (bad for the starter/battery) and plugs may have to be removed to push any water or fuel out. Then, before putting the plugs back in, it's probably a good idea to squirt a little oil in the cylinders to restore some compression. Fuel particularly will wash-down the cylinder reducing compression. If the ECU thinks the car is getting huge amounts of air, it will dump fuel in, so, maybe the MAF (or MAP?) was affected by the engine cleaning procedure? that's all I got.
I think the ECU on 00-04 (?) H6es maybe handles the field current so, perhaps some OBDII/newer cars use the ecu for field current? anyway, I assumed due to the age of the vehicle in the OP, it was probably supplied thru the bulb.
with the rear of the car on jack stands, I had to use my floorjack's platform on the end of the 1/2" breaker bar to get the plugs loose. Cheater pipe probably work OK too. On your 2009, you may have 13mm square (most people find the 1/2" breaker bar will work OK) or you may need to buy a T-70 torx bit. You can get then Autozone I think, goy mine from Amazon IIRC. it can also be tricky filling the rear diff. I bought a gear oil pump like this;
Not familiar with the 2012, but does seem he may have drained coolant, then put coolant in the transmission. Unless he can satisfy himself that he has all the improper liquids OUT of wrong places, and proper liquids at proper fill levels IN the right places, best to have it towed to a shop and fixed up. We will need to know more about the car, which engine/transmission, etc. (Once, I forgot to replace a drain plug ans poured about 2 quarts of new oil on the ground until I spotted something flowing past my feet - feces happens!)
well, I have no idea if it will fix the 'miss', but I discovered I seem to have a crack in the Y pipe under the intercooler. Well, actually, at the elbow to the turbo. Never took the IC off before. There's some kinda foam insulation taped on the part, and there is grime built up ONLY on the elbow, it's clamp, and the foam next to it. None on any other part nearby. I'm thinking it got stressed when I had the dealer do an 'indcution' service and replace the PCV valve back when the car was getting a wheel bearing installed. so, I have a MIshimoto kit coming. I'll probably know in a week or 2 if it helps the problem. I'll try to take pics. Such low miles, seems like the car is not aging well.
- 85 replies
does the problem track with fuel LEVEL? If not, the jetpump is OK. There have been a coupla posts ov er the years of people having fueling issues at low tank levels - stalling when turning or ??? , due to the jet pump (it is some kinda venturi deal using the return flow into the tank to push fluid over to the pump side of the tank) being bad/clogged. I suppose it wouldn't hurt to run some SeaFoam or Techron through a tank of fuel. might be helpful, it isn't expensive. another 'out there' but easy thing to try, pull the Crank Position Sensor and clean it. There have been reports of ferrous 'dust' collecting on it causing occasional misfires.
Not synthetic, even though at least one on-line retailer has mistakenly listed it as synthetic. maybe they corrected it by now? (Fredbeans.com) On older transmissions, folks have tried synthetic and reports were not good as the synchronizers would not spin-up fast enough. thee is a HUGE thread at NASIOC (scotty's cocktail) about people trying to get theire transmissions to better with different fluids. It's crazy. But, you could search through it for comments about Motul, Redline, Mobil 1, Royal Purple, Valvoline, etc. I've had good luck with Redline Lightweight Shockproof, but it doesn't really save you any money. Going to use Extra-S at my next fluid change. But, I also use the time side of the schedule. (2006 WRX at 44K miles)
