105
well, I have no idea if it will fix the 'miss', but I discovered I seem to have a crack in the Y pipe under the intercooler. Well, actually, at the elbow to the turbo. Never took the IC off before. There's some kinda foam insulation taped on the part, and there is grime built up ONLY on the elbow, it's clamp, and the foam next to it. None on any other part nearby. I'm thinking it got stressed when I had the dealer do an 'indcution' service and replace the PCV valve back when the car was getting a wheel bearing installed. so, I have a MIshimoto kit coming. I'll probably know in a week or 2 if it helps the problem. I'll try to take pics. Such low miles, seems like the car is not aging well.
- 85 replies
does the problem track with fuel LEVEL? If not, the jetpump is OK. There have been a coupla posts ov er the years of people having fueling issues at low tank levels - stalling when turning or ??? , due to the jet pump (it is some kinda venturi deal using the return flow into the tank to push fluid over to the pump side of the tank) being bad/clogged. I suppose it wouldn't hurt to run some SeaFoam or Techron through a tank of fuel. might be helpful, it isn't expensive. another 'out there' but easy thing to try, pull the Crank Position Sensor and clean it. There have been reports of ferrous 'dust' collecting on it causing occasional misfires.
Not synthetic, even though at least one on-line retailer has mistakenly listed it as synthetic. maybe they corrected it by now? (Fredbeans.com) On older transmissions, folks have tried synthetic and reports were not good as the synchronizers would not spin-up fast enough. thee is a HUGE thread at NASIOC (scotty's cocktail) about people trying to get theire transmissions to better with different fluids. It's crazy. But, you could search through it for comments about Motul, Redline, Mobil 1, Royal Purple, Valvoline, etc. I've had good luck with Redline Lightweight Shockproof, but it doesn't really save you any money. Going to use Extra-S at my next fluid change. But, I also use the time side of the schedule. (2006 WRX at 44K miles)
seems suspiciously like it could be a fuel LEVEL problem. there's a jet pump in the tank that is supposed to move fuel over to the right side. maybe it's partly clogged? Might also be worth inspecting the cap/o-ring on the fuel pump. A coupla of people have found 2.5s with that problem. is it more likely to happen in rain or fog? maybe the coil is arcing? you didn't mention servicing the PCV valve, though I can't really see it being the problem.
I used the same stock number. Remeber, I changed the plugs to try to fix the problem, it didn't change anything. The coils and the 'snoots' etc. all looked good. No oil. did that 2.o set any misfire codes? And the guys ocer at scoobymods that thought I had a knock problem were just confused by my having a 32 bit ECU. The IAM number starts at 1 and not 16. They though I had huge knock and the system was pulling timing. As a coincidence, RockAuto was out of stock so, I canceled the knock sensor order. It wasn't gonna be expensive, but don't really see a reason yet to swap it. this is what the log looks like - all 3rd gear at wide open throttle from 2K to near redline ; there are 2 weird cells, Ignition total timing at 3978rpm , and engine load at 4898 . I have no idea if artifacts like that are common, if I was logging too many parameters or if the car missed or ????? I have another runn I need to look at, just hard to get excited about it. I don't understand half of that stuff or how it inter-relates. Clearly, doesn't look like I need to log the variable valve system anymore. Probably don't need intake air temp or all those mass air flow/manifold numbers either.
- 85 replies
lol! They must be taking a lesson from Microsoft, "it isn't a bug, it's a feature!' many people would set the parking brake if on an incline - but this still smells like BS to me. when they say "they all do it" I have had good luck with 2 different replies; (look around lot for the same car) "Give me the keys to THAT one and let me see if it does it" or "If they all do THIS, then they are ALL broken, and they need to be fixed, and you can start with mine!" take your pick. if you want to be a little more 'mild', look the person in the eye and ask how he would feel if HIS car had this 'feature'!
, I have Huper Optik (mentioned above) on my 06 WRX. Been on there since spring of 06. It sits outside here in Texas all the time. No weird colors, no bubbles yet. Some very slight distortion around where the edge of the windows rest on the seal. Only visible when I lower the windows. The car is still hot when you get inside, but it cools off very quickly and probably helps the A/C keep up. Protects the interior too I guess. The HO material is ceramic so, might be less attenuation for radio, gps and cellphone signals.
just wondering if the alt is getting 'field current' but, I'm unsure exactly if the bulb or some diode somewhere might be the problem.
burned-out 'batt' bulb? doesn't current flow thru it for the alt. to work?
eh - RA is out of stock. I canceled the KS. I dunno, might try to post my log at the romraider Forum, hope those guys aren't cranky like over at NASIOC.
- 85 replies
no mention of a boost problem. I could post the log here if anyone is interested. I don't understand half of it. I think the boost is OK. They seem concerned about the IAM which is one of 3-4 parameters related to timing. I think also you may be right Ivan about the sensor's mount location maybe not grounding well(but the sensors has a 2-wire connector i think?). My car stays outside and, as I've mentioned before' I already had to kill the codes for the secondary air valves and pump due to them rusting closed in 4 years. So. if the knock sensor is prone to corrosion issues, maybe a new one is called for. I'm hoping it won't be too tricky to replace or clean under. I plan to try to at least wire-brush under it. I understand I have to duplicate how the pigtail 'dresses' away from it due to some lumps and bumps on the block around the mount area. i may need to pull the intercooler - never did that before.
- 85 replies
I logged a pull with RomRaider and one person at scoobymods thinks I may have a bad knock sensor. I can get an airtex wells unit from RockAauto for $40 . thinking about just swapping it in. can't get over it being bad at 44K miles but, I dunno, maybe some corrosion got under it?
- 85 replies
