105
very unlikely, 'warped' (usually uneven deposits from pads, extremely rare to actually 'potato chip') rotors would be felt when applying brakes. Not to say stuck calipers could cause issues. https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjRosfmsZbxAhXDG80KHWfmBDMQFjAAegQIAxAD&url=https%3A%2F%2Fcentricparts.com%2Fgetmedia%2Fbd69395a-b65c-481d-93f7-b26b1bd0638d%2FCentric_and_APC_Technical_Whitepaper_B1-Warped-Brake-Disc-8-2018_1.pdf&usg=AOvVaw2Syl_CnageQ47I6fsJZy3W check toe in the front. I don't recall the first page but, inner tie rods, ball joints OK? Maybe bad steering rack bushings could do this???
the only way I got an axle out of my daughter's Impala hub was a little heat and penetrating fluid - after much force with 3 jaw puller pushing on the axle and an impact tightening it and a big hammer, etc. 20 seconds of propane at 6 and 12 o'clock. didn't car about any rubber as everything was getting replaced anyway. Becareful not to start a fire. car was rust free too. My guess is, there's enough moisture can condense or wick? on the splines over the years to make rust due to limited chance of drying out the tight space?
Dual range transmission problem on 1986 Subaru
1 Lucky Texan replied to 3crows's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hmmmmm, I have no experience with models this old, but, have you recently serviced the trans? Did you use synthetic lube? -
Man, I could not even find a good video on using manifold gauges. I use the them for vacuum application and charging, etc. But the whole pressure ratio thing is hard to discern for me. I can tell you, the system can make a 'hooting' noise if it is overcharged so, there's that. It is sometimes helpful to use a box fan to blow into the radiator too I think.
until you get into dual climate, most cars have 3 'flaps' with electric servo motors/controls. A flap/door for fresh/recirculate, one for defroster, and the one I think stuck or failing on your car us usually called the 'blend' door I think. FSM or some diagram from an image search might show you it's position in the car.
High angle CV boots
1 Lucky Texan replied to Ionstorm66's topic in Old Gen.: 80's GL/DL/XT/Loyales...
just realized - boots - so, pay no attention to me...... -
High angle CV boots
' plunge shaft ' yeah baby
