105
Hey, 1975 called, they want their hair back! lol! this is me about 1975 plus/minus a year or 2;
- 420 replies
- Loyale 2.7 Turbo
- JesZeK
- (and 8 more)
I recently had a 13 loaner Outback and found (other than all the electronic gadgets) it really only felt 2-3 years more 'advanced' than our 03 H6 Outback. Road noise seemed about the same to me. and, a few weeks later, I had a 13 Ford (um, Edge I think) and it had a several bad ergonomic problems I thought - and road noise. seems like they just wanna throw electronic gadgets in cars instead of 'real' engineering nowadays.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&ved=0CFwQFjAE&url=http%3A%2F%2Fwww-odi.nhtsa.dot.gov%2Facms%2Fcs%2Fjaxrs%2Fdownload%2Fdoc%2FUCM431591%2FRCDNN-12V602-9293.pdf&ei=XuzlUOucPIWA2AXllYEg&usg=AFQjCNFiVqwosdpac7L6uwCDCbLwVqGDRw&bvm=bv.1355534169,d.b2I looks like the cable or PCB will get a 250mA fuse at each puddle light location.
the paragraph just prior to the statement quoted has a list of presupposed conditions too. I think also, there's a difference between 'thickness variation' and something shaped like a Pringles potato chip that would have the same thickness all around. (actual warpage) I suspect, more often than not, pad deposition is causing pedal pulsation and probably other problems on road cars. Of COURSE, rotors (and wheels for that matter) can be installed incorrectly or be bad from the factory.
I have no idea if pad material can break down with time so, I'd say your calculations are as good an indicator as anything else would be. I suppose it might still be a good idea to tear down and lube stuff as I'm sure exposure/time/corrosion etc. can still affect the slide pins and other moving parts. In the US, there can be a slight asymmetry to pad wear favoring the pass side. this is due to parking at the curb where gravel, leaves and other debris may allow a little sliding that the DS doesn't experience. This is most extreme on Postal Vehicles but, the DS is probably the best 'tattle-tale' for general pad wear. And, suppose a caliper is sticking at one of the other 2 corners?
were the heads off the car for a long time? I once had a Honda engine mostly disassembled but still in the car, in my driveway. and, after I put it back together, the oil pressure relief valve was stuck. I suppose I'm wondering if just being exposed for a while could lead to some gummy/varnish forming on the pistons/oil control rings.
here's my story; http://www.subaruoutback.org/forums/66-problems-maintenance/40884-how-does-air-get-into-power-steering-system.html since then, I have had no problems. You should be aware there is also a TSB concerning the pressure relief valve in the side of the pump (maybe H6 engines ??? not sure) that can cause groaning but it seems the symptom is groaning at full lock. bubbles/foam is no good. anyway, fix the o-ring, put screw-type hose clamps on both ends of the suction hose after inspecting it for cracks. repalce as much old ps fluid as possible with Dex III compatible fluid.
4.1 ratio diff matched with 4.11 ratio...
1 Lucky Texan replied to el_freddo's topic in Subaru Retrofitting
I have no experience but, when these type issues come up, I often wonder if there's a way to compensate with different tire sizes on front vs rear axle. maybe not practical for many people but, just a mental exercise hah! -
Cel
1 Lucky Texan replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
code probably still pending or otherwise retreivable. swing by a PepBoys or other such place, they will read the code at no charge. Have them clear the ECU if they will and report the code(s) here. Monitor how quickly the light comes back on and be prepared to have the system read again but, it seems it will set the code repeatedly.
